Looking at trading in the 7.3 - Diesel Forum - TheDieselStop.com
Old 08-01-2006, 11:52 PM   #1 (permalink)
can't decide between the 6.0 or the chevy with duramax. what are your thoughts and why?
02 F250 PSD CC SB 4x4 Auto Tranny, AIS intake, ISSPRO guages, MBRP 4" T304
Towing an 05 Sprinter 294FWDB 5th wheel
hhills is offline
Old 08-01-2006, 11:54 PM   #2 (permalink)
Send a message via AIM to PaCeMaKeR
Re: Looking at trading in the 7.3
keep the 7.3
2002 PSD modded " tow rig"
92 Dodge Cummins
86 Buick Grand National
PaCeMaKeR is offline
Old 08-01-2006, 11:56 PM   #3 (permalink)
Which one is the better money deal?
With any of the auto manufacturer's you pays your money & takes your chances.
My 03 has been a good running, comfortable truck, and was $1000 cheaper the Duarmax I was looking at, and I couldn't get a straight answer outa the Dodge dealer.
Drive them both, and see which one is best for you.
OMCUSNR is offline
Old 08-02-2006, 12:26 AM   #4 (permalink)
the 7.3 is paid for and has been for a while. I have taken real good care of it but am concerned with the problems I have had,
1. power steering pump went out under 5k (not that big of a deal)
2. cps went out (pretty common)
3. found 2 oil jet coolers in the oil pan (a bit of a problem)
4 fuel sensor went out (small problem
5. now have a binding issue when towing my 5er up an incline from a dead stop. seems like the 4 wheel drive is binding and I am only in 2 wheel drive.
figure I would get a new truck before the emission changes in 07
hhills is offline
Old 08-02-2006, 01:16 AM   #5 (permalink)
I have many fords, chevys, and dodges for my business. I will never have another ford 6.0. I have a 99 7.3 with 328k miles and still going strong with few minor problems, my 02 7.3 with 90k has not gone in the shop for one thing. My own personal truck 04 6.0 with 45k has been in many times for wiring harness problems and injectors. And my wives 04 duramax with 50k has not been in the shop for anything. All of my dodges with the cummins have held up very well except for the automatic transmissions and having to replace the brake often. If I was you I would be getting a duramax, my next personal truck most definetly will be one.
timeforadmax is offline
Old 08-02-2006, 07:19 AM   #6 (permalink)
If you have SOF, your hubs may not be unlocking.
I wouldn't be afraid of a new 6.0. I am looking real hard at replacing my '02 with an '07 myself.
Mike
'07 Dark Stone F-250 Lariat CC SB FX4 6.0 Auto, LS, power sliding rear window, power moon roof, 20" Goodyear Wrangler ATs.
Truck pic
Lineman is offline
Old 08-02-2006, 07:38 AM   #7 (permalink)
rock_doctor's Avatar
The broken oil jets will be covered under the engine warranty (providing you do not have more then 100k on the clock) and yes this is a big problem. If you are having drive train binding problems with the 4wd system make sure the hubs are actually unlocking. You may have a stuck hub.
good luck,
mark
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 08-02-2006, 10:53 AM   #8 (permalink)
what is SOF? The Oil Jets were covered under warranty last year. My truck just turned 48K on the Odometer.
How Do I check to see if the Hub is stuck.
hhills is offline
Old 08-02-2006, 10:54 AM   #9 (permalink)
POS
You've got a 7.3 with only 48k miles on it? Keep it!
The thought to get a new truck should be based on your lifestyle and what you want. For me, if I wanted a new truck, the Chevy has a better interior.
<font color="red"> WIX filters at </font><font color="blue">www.fleetfilter.com</font>
POS is offline
Old 08-02-2006, 01:07 PM   #10 (permalink)
The warranty on the engine is 100k miles and 5 years. You are still under the engine warranty. Get it to the dealer asap, will cost you $100 deductible... Basically everything that touches oil or emissions system is under the extended warranty.
Hopefully you still have the jets that fell out when you changed the oil.
SOF - shift on the fly. The transfer case is engaged via an electric motor and the hubs lock and unlock via a "puff" from the vacuum system.
Jack up the front end and see if each wheel turns w/o turning the front shaft.
Good luck,
mark
Old 08-02-2006, 01:43 PM   #11 (permalink)
Good luck,
mark
Thanks for the help. The oil Jets have been replaced, what an ordeal that is.
I will jack the truck up and check the shaft. I do have shift on the fly
hhills is offline
Old 08-02-2006, 03:13 PM   #12 (permalink)
im on my second 6.0L and they suck. i love the truck but i just started to have a problem with the '06. it didn't start yerterday, and had oil leaking issues when it was one month old.(that was fixed) the '06 is alot louder than the duramax and cummins, and ALOT louder than my '03 (no big deal). my '03 was a buy back and got the '06 cheap, now im starting to wonder if i made the right decision? if i had a 7.3 i would keep it as long as i could. i'v heard some guys that have duramaxs tell me they have various problems too. i have not heard anything bad about the cummins motors. im not a fan of dodge trucks but that is the one i think has the LEAST amount of problems.
'06 f250 6.0 crewcab lariat 4x4
jim
jimmyk7 is offline
Old 08-02-2006, 05:34 PM   #13 (permalink)
dodge has problems with the auto tranny, and the rear seat space is the smallest of the 3
hhills is offline
Old 08-02-2006, 05:55 PM   #14 (permalink)
Take your 7.3 in, or get a 6.0. If you must get out of a ford, get a Dodge, almost bought one myself only thing that stopped me was the interior space and the new front end. Now that I have a 6.0, I love it though, more so than the dodge.
06 Cummins, White, CCSB
Smarty POD
MP8
Flux 3s
II SB66
Hamilton 110 Springs
Hamilton Big Stick
AirDogII
All shifted by a full billet HTS
rubberducky is offline
Old 08-02-2006, 06:13 PM   #15 (permalink)
Ok, guys, once more, with feeling. The Chevy truck is a piece of crap. I'd rather have a mid-90's Ford than a brand new Chevy at any cost. My employer leases these trucks, and they constantly FALL APART! They are cheap as hell from the bottom up, and I really don't care if they have a rocket engine in them. You will be disappointed if you are used to a Ford. Their diesel engine has plenty of power, until the compression blows the head gaskets out of it because it has aluminum heads on a cast iron block. It was a poor design from it's inception, and I am suprised that the Japanese would do it that way.
With that said, I have made the swap from 7.3 to 6.0, and both of my trucks have been very good to me, however, I don't tow heavy too often, but I do run it rough daily. There are some amenities absent from the '02 to the '05 that I noticed right away, and was unhappy with. My new truck has more power at high rpm, less at low rpm. All in all, I am happy with my '05, it has been trouble free for the 24K miles I have put on it. Later '02 7.3's have cheaper connecting rods in them, which pushed me in the direction of the 6.0
Dodges can't keep auto trannies behind them. If you will settle for a stick, you might be OK.
Just my opinion, take ir or leave it.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
