losing coolant, lacking power - Diesel Forum - TheDieselStop.com
Old 11-29-2007, 07:27 AM   #1 (permalink)
mine is constantly puking whenever pulling heavy load or when driveing over 55 mph I also notice it doesn't have the quick power responce that it use to have and the turbo is fluctuating. I have taken it to ford they said it was a bad pressure cap but that did not cure the problem. I have lowered the coolant level to 1" below the min line checked for water leaks but still have the problem
05 F350 CC LWB lariat dually 4x4 6.0 6 speed automatic
06 navigator ultimate 5.4 6 speed automatic
00 F150 XLT 4.6 automatic with lincoln nav front end
70 mach 1 351C automatic ac restored original
64 fairlane with 95 mark VIII drive train
60 pontiac bonneville 389 w/3 deuces 43k miles original
deuceswildpacefl is offline
Old 11-29-2007, 08:02 AM   #2 (permalink)
OneTonHillBilly's Avatar
Re: loseing coolant, lacking power
Have them test for HG's or EGR Cooler failure. When the EGR Cooler goes, there is a loss of power but usually so much white smoke you can't see the cars behind you.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">05 F350 lariat dually 4x4 6.0 6 speed automatic</div></div>
???? You have a typo there
2007 F-350 CREW SRW Lariat Outlaw(Bought New By Me)
This Thing Is Going To 200K With Me Behind The Wheel!
OneTonHillBilly is offline
Old 11-29-2007, 09:39 PM   #3 (permalink)
I have no white smoke problem. I have noticed that the fuel mileage is down 4 mpg from what it was thou
Old 11-30-2007, 04:46 PM   #4 (permalink)
OT
OT's Avatar
Re: losing coolant, lacking power
TSB's list "specific" tests for puking/loss of power & mpg.
Obviously c.cap didn't fix your problem. As mentioned (specific or combination bad parts) bad HG(puking/loss of power) turbo (power loss) f.i.(power/mpg loss) EGR cooler etc. No smoke, but did you notice any oil in coolant? I'm not a tech., but wondering....
If a competent 6L certified tech. replaced cap to correct your puking, seem's specific tests would have been performed. If done then nothing else was found to be defective, right? Meaning you may need to find a new tech? JMO!
btw..if tech.can't duplicate concern's IN HOUSE, then you'll need to figure out how that can be accomplished. Good luck!
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 12-01-2007, 08:19 AM   #5 (permalink)
thanks for your replies I did an easy check that was recomended on here, the one were you stand on brakes in drive and rv engine up to get boost power and check for bubbles in coolant reserve bottle, I definately have blown gaskets already called another ford dealer to get it in biggest problem I have is the say down time 2 to 4 weeks. again thanks for your tips
Old 12-01-2007, 05:07 PM   #6 (permalink)
did you hafta warm up the engine first before ran the test? (i.e. open up thermostat or bring EOT up somewhat)
also, how long before the bubbles appeared in the reserve bottle?
Thanks!
2003.5 F350 4x4 CC Lariat, 6.0 Auto, Solid Black, Leather, 40/20/40, Loaded. Ordered 1/29/03, Built week of 2/24/03, Delivered 3/14/03
Added: B&W Turnover Hitch, Line-X Liner, Magnum bug deflector, chrome winks, Husky liners, Prodigy brake controller, warranty work @24K mi 10/05: new EGR, EBP, ICP, 4 injectors, fuel tank (leak), 1st flash
huntjock is offline
Old 12-02-2007, 07:45 AM   #7 (permalink)
we came in with the truck warmed up, took the pressure cap off, topped off the reservoir and did the test. It immediately started to pump water out and bubbles in few seconds. that is my experience I don't know what would be normal.
