Loud air noise - Diesel Forum - TheDieselStop.com
Old 08-14-2006, 11:26 PM   #1 (permalink)
Loud air noise
Need some help please,I was towing heavy load today and all the sudden
it sounds like the blower motor on A.C. went to warp speed.It must be
turbo related because when you back off the noise goes away.When you get back on it and boost starts to build noise comes back.This is a 04 F350 4wd with 52000 miles on it bone stock. I did not notice much
power loss, might be a hole in one off the intercooler boots.
Thanks for any help Willie J.
2004 F-350 6.0L 6-speed build March 04
Willie J. is offline
Old 08-14-2006, 11:37 PM   #2 (permalink)
Re: Loud air noise
Are you sure it isn,t the PCM controlled cooling fan kicking in. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 08-14-2006, 11:50 PM   #3 (permalink)
FamilyRide's Avatar
Re: Loud air noise
If not the fan, the sound is different, check the blue boots on the IC tubes at the turbo and also at the IC. Mine split and under boost you could hear it.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide is offline
Old 08-14-2006, 11:56 PM   #4 (permalink)
Re: Loud air noise
it is the turbo boot. check for little pin holes.
2004 F-250 6.0 PSD,4" Custom exhaust w/5" tip,Air-Raid intake,Zoodad mod w/Zoodad lid,6.5" ProComp lift dual shocks with rez.,bagged AirLift,37x13.50x18 Mickey T's,sct LiveWire,3 gauge pillar (B.E.T.), ProComp 2xStreering Stabilizer,Diamond Plate Tool Box,Line-X,adjustable Bully steps,Garmin Navigator and 7" tv's in the back for the kids [img]/ubbthreads/images/graemlins/smile.gif[/img]
gotturbo is offline
Old 08-15-2006, 12:04 AM   #5 (permalink)
Re: Loud air noise
IS THERE ANY OTHER CHEAPER HOSES OR BETTER HOSES THAN THE BLUE TURBO HOSE FROM FORD THATS $80?
MODFATHER is offline
Old 08-15-2006, 03:59 AM   #6 (permalink)
Re: Loud air noise
Thanks for your help,I will check the boots in the morning.
Willie J.
Old 08-15-2006, 11:54 PM   #7 (permalink)
bersa45's Avatar
Re: Loud air noise
check boots, but also if belt is old change belt, fixed my noise.
2005 F250 CC 6.0 3.73 rear end white/silver short bed 4x4 lariat loaded, Sirius radio,cb,locking glove box,Ruger SR9,harpooned fuel tank pulling 33' Rockwood TT, with 116,000 comfortable miles!!
bersa45 is offline
