low oil pressure at startup - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-11-2008, 09:54 PM Thread Starter
This is probably a dumb question, but I just got my 04 Powerstroke 6.0. When I start it the check gauge light comes on and I have no oil pressure. Once it warms up the check gauge light goes out and the oil pressure raises to normal, then it drops for a second and goes back to normal. Is this supposed to happen? and will it hurt to not let it warm up and drive with the check gauge light on and low oil pressure (according to the gauge)? Any help with this will be appreciated.
cbrmarengo is offline
post #2 of 7 (permalink) Old 04-11-2008, 10:51 PM
No thats not normal. I assume you have checked the oil level. It would not start without oil pressure. If it starts and runs fine other than the problem you mention, then I would assume you have an indicating problem.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
post #3 of 7 (permalink) Old 04-12-2008, 12:16 AM
dieselmankane's Avatar
yes i would have to agree. that does not sound normal at all. At least, my truck doesn't do that. When i start my truck, it takes a few seconds, but oil pressure builds right away. Maybe oil leak, or maybe worn engine? have you done an oil analysis lately to see if anything suspicious is going on? How many miles on engine?
dieselmankane is offline
post #4 of 7 (permalink) Old 04-13-2008, 01:36 AM Thread Starter
Thank you for your help
After further investigation I found that the previous owner for some odd reason cut the dipstick handle cup off of the handle, Thus resulting in low oil pressure. Thank you for your help though.
post #5 of 7 (permalink) Old 04-13-2008, 01:40 AM Thread Starter
Thank you for your help but after further investigation I found that the previous owner for some odd reason cut the cup off of the dipstick handle! Why? I have no idea but that was the problem. I used electrical tape to seal the dipstick handle to the tube until my new dipstick is delivered. Thank you again for your response.
post #6 of 7 (permalink) Old 04-13-2008, 02:03 AM
that will have no effect on it seeing the motor has a crank case ventilation system so there is no pressure in the oil pan. The oil pressure is pumped in 2 fourms, the LPOP that is run from the crank and the HPOP in the vally of the motor..
LPOP Page 23: Lubrication System
some after market oil filters will not press the oil stand down hard enuf to let the oil flow correctly back down threw the oil cooler. stick with motor craft or International parts.
bcarriveau is offline
post #7 of 7 (permalink) Old 04-13-2008, 02:11 AM
