Low Voltage at trailer connector - Diesel Forum - TheDieselStop.com
Old 08-04-2009, 10:38 AM   #1 (permalink)
Hey all,
It seems as though my trailer batteries are not charging while being towed behind my pickup. I measured the voltage between the +12 pin and the ground pin on the factory trailer plug receptacle mounted on the hitch. There was just under 12 volts with the engine running. Does this seem low, or is it normal? The voltage across the battery terminals is around 13.75 with the engine running. Any ideas for troubleshooting?
Nubbs
07 CC LB FX4 TS 6.0 Oxford White, 4.5" DR lift, 315/70/17 BFG on 17x8 American Racing Mojave
Nubbs is offline
Old 08-04-2009, 12:48 PM   #2 (permalink)
Voltage should be close to the same as the battery voltage with the engine running. I had the same issue and it was corrosion in the trailer plug where the wires plug in from the truck harness. Cleaned everything and all was good again.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
Old 08-04-2009, 12:58 PM   #3 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Me too...I had only 2-3 volts charging battery for my camper. I ended up cutting the wire off about 2 or 3 inches back and replacing plug.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 08-04-2009, 01:10 PM   #4 (permalink)
Thanks for the tips. I'll check it out.
Nubbs is offline
