lower radiator hose - Diesel Forum - TheDieselStop.com
Old 08-19-2006, 03:53 PM   #1 (permalink)
lower radiator hose
Folks,
On my 2004 Excursion TD EB, the lower radiator hose looks like it's pressing against a box of some sort which is wearing away the hose and causing it to leak. Does anyone have any ideas about this?
thanks,
keith
Ford Excursion 2004 6.0l PSD Eddie Bauer
<font color="gold"> 2 wonderful Golden Retrievers </font>
http://www.goldenretrievers.org
clayk is offline
Old 08-19-2006, 10:33 PM   #2 (permalink)
Re: lower radiator hose
Yes, all stock trucks do this if they have the 6.0. The best you can do yourself would be to disconnect one end and slip something over it to stop the abrasion and twist it when re-installing it.
'03 "TNT Ranch Edition" F350 CrewCab Lariat 4X4 DRW, 12V Cummins, P&P head with 60# valvesprings, PDR QuickSpool cam, built pump with 4K GSK, S366 Turbo, ZF6spd. with Valair Ceramic/Kevlar, manual hubs, 3.73's, 5.5" lift w/285 Dayton Timberlines, 2" DRW Spacers.
Bullrack is offline
Old 08-19-2006, 11:32 PM   #3 (permalink)
hitecdan's Avatar
My Photos: (22)
It's a common issue with this engine/truck combo. The lower radiator hose rubs against the steering box and the steering linkage.
What I did was replaced the lower hose with a new one. Then I took the old hose and split in lengthwise. Then wrapped the old hose around the new hose in are contact areas for a custom fit. I secured the old, now outer hose, with hose clamps to keep everything in place.
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 08-20-2006, 11:45 PM   #4 (permalink)
Mine came with a nylon webbing around the hose. Made sure it was between the steering gear box and the radiator hose 40k back, and its still doing its job.
OMCUSNR is offline
Old 08-21-2006, 10:21 AM   #5 (permalink)
I actually glued (3M spray) a small piece of rubber to the steering box where it made contact.
jward is offline
Old 08-22-2006, 08:54 AM   #6 (permalink)
When I noticed my '03 had rubbed almost all the way through I had it replaced under warranty. The new part had an updated number (ended in -EA instead of -AA or something like that) and is nowhere near the steering box now.
I'm not entirely sure what that webbing is for, but I don't think it's for this. It would delay the damage through, what, another 10 minutes of rubbing?
Make sure to look far up the hose for this damage. There's an obvious rub spot down low that I had been keeping an eye on and purely accidentally discovered the actual rub spot farther up, just before it was too late! Here's some pictures I took at the time:
http://www.backglass.org/duncan/psd60_hoserub.jpg
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
frobozz is offline
