Map sensor not hooked up, not showing any CEL? - Diesel Forum - TheDieselStop.com
Old 08-06-2009, 03:12 PM   #1 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Just finished doing studs and headgaskets on an 04 6.0L. Hooked everything back up, truck started without much of a fight. The plastic nipple on the MAP sensor got broken off while putting everything back together so it isnt currently hooked up.
Truck still seems to run fine, plenty of power, no excessive smoke, etc....
I ordered a new MAP sensor which will be here tomorrow, but I thought the MAP sensor was critical to correct operation of the motor? Any ideas why there are no CELs?
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 08-06-2009, 09:45 PM   #2 (permalink)
bigwhite1's Avatar
i beleive the map sensor was taken out of the equation a while back, so it's not used.
unfortunate owner of a 2006 6l diesel,lb,cc and formally a 2004 6l. both puke and both not fixed by ford under warranty
2004 cardinal 33ts
bigwhite1 is offline
Old 08-06-2009, 09:53 PM   #3 (permalink)
My Photos: (10)
I see, everything else I read so far says it uses manifold pressure (boost) to adjust fueling and timing.
