Old 10-31-2009, 09:41 PM   #1 (permalink)
max EGTs???
I have a edge juice w/ attitude chip, afe 4in exhaust and afe intake in stalled on my 05 F350. what would be the high point for egts to go to just trying to figure out my max for the edge chip. thanks.
ocwrestler160@yahoo.com is offline
Old 11-01-2009, 02:11 PM   #2 (permalink)
teamroper60's Avatar
You should not run sustained temps over 1250 degrees.. But short bursts (a few seconds) well beyond that are fine. You could set that back down to 1300 degrees and just monitor your EGTs to make sure you don't go over 1250 for extended periods....
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, AIC, MBRP turbo-back exhaust, Tuning by Tony Wildman (Total Diesel Performance), ARP studs & some "other" work done by River City Diesel, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-01-2009, 05:14 PM   #3 (permalink)
I have an edge Juice with attitude 4 inch magnaflow and an AFE airbox as well. The highest EGT I seen was 1250 towing a 8000 lb toy hauler while ascending a steep mountain.
2004 F350 Lariat FX4 Crewcab Turbo Diesel SB W\ 80,000 miles and going strong!!
-AFE stage 1 Airbox, 4 inch Magnaflow Exhaust W/ no cat and 5 inch inch Chrome Tip, Edge Platinum Juice W/Attitude Module, And of Course A Laser Radar Detector!!!
-2.5 inch Rough Country Front Leveling Springs and shocks
-33 inch Toyo Open Country tires
- ZooDad Mod
- DieselSite Coolant Filter
-2008 26 feet Nitrous Hyperlite Toy Hauler Loaded
with all the options
BigMike33 is offline
Old 11-01-2009, 11:44 PM   #4 (permalink)
dikkstarr's Avatar
Mine is stock tuned and can pass 1250* if I tow but it scares the crap out of me. I even get scared if it goes above 1000*. Sux.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , white with 12" lift, flip steering, 38s on 17 10s, stock gears, superlift truspeed, fumoto, floating traction bars, airraid intake with elbow,4" turbo back, studded, powerslots, 55 watt HIDs 6000k heads and fogs,clear corners,7" NAV w/ back up camera, massive stereo, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,,coolant filter kit,hush panels and door seal mod,
dikkstarr is offline
Old 11-02-2009, 09:27 AM   #5 (permalink)
Pre or Post Turbo? I hear it makes a difference.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 11-02-2009, 11:57 AM   #6 (permalink)
thats pre turbo cause my sensor is in the intake manifold i believe
Old 11-03-2009, 09:21 PM   #7 (permalink)
wpfd's Avatar
yes ur sensor is pre turbo in the exhaust manifold. as long as ur not sustained over 1300* you will be fine. keep your edge setting in the lower levels when on a hill and/or if your towing. if your EGTS burst up over say 1500* then id back her down thats a pucker level....
mine is set at 1250 to give me a heads up in case she starts surging over 1300's...
2003 Ford F350 6.0 Crew Cab/SB/SRW 4x4
Edge Juice Platinum w/ Attitude Controller
Bully Dog RFI Intake
MBRP 5" Turbo Back Straight Pipe Exhaust, Cat Delete
piloting a fire breathing, over boosted, turbo charged, tire smoking, panic inducing, ear drum abusing, spinal adjusting, snow storms nightmare. 2003 f-350 6.0, kinda fast...
wpfd is offline
