max egts and boost - Diesel Forum - TheDieselStop.com
Old 03-13-2005, 05:32 PM   #1 (permalink)
max egts and boost
What are my max egts that I dont want to go over 1300*
What is the safe limit on the max boost?
2006 Red Chevy 3500 Duramax Diesel / Allison 6 speed Auto LT Dually, all power Leather seats.
Traded 9/27/05 2004 Black F-350 XLT Chassis Crew Cab 4x4 6.0L Powerstroke, 6 speed, 4.10 LTD Slip, Security package, Aluminum wheels, AIC, 9' Aluminum Flatbed, Edge juice w/ attitude, custom Billet "F-350 Cattle Hauler" badges and Custom "Juiced 6.0 Powerstoke Palmer Livestock" diesel door badges.
04' F-350 Chassis Crew Cab
Engine Build- 8/28/03
Truck Build- 9/03
Hauling cattle with a 2004 24' and 2005 28' Gooseneck Brand Cattle Trailer
ChassisCrewCab is offline
Old 03-13-2005, 07:06 PM   #2 (permalink)
dbennett48's Avatar
Re: max egts and boost
I use 1200* for my upper limit. 1300* is too high. I am stock. There is no boost limit. Your computer limits the boost by changing the vanes in the turbocharger to keep it in line. 30Lbs is the most I have seen. 28-29 lbs is normal.
Dave
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!!
http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
dbennett48 is offline
Old 03-14-2005, 06:13 PM   #3 (permalink)
Most say that if you hit 1250 on the EGT let off the throttle to let them cool and I have heard that the garret turbo on the psd is good up to 45-50 psi boost but your computer will cut you off at 28-30 psi stock. chiped you will see more 35+. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
P.S. The 1250 max EGT is pre turbo mounted.
Nick
2005 F-350 Lariat 6.0 PSD CC Dually 4x4
Big Black Beast
Born 2/14/05 delivered 2/28/05 Purchased 3/1/05
2000 X Limited PSD 4x2 Stock. SOLD
Nick_Kowal is offline
Old 03-14-2005, 11:00 PM   #4 (permalink)
I have seen 1300 stock and 1500 with tuner only brief seconds my gauge reads faster than my old analog gauge I am using Bully Dog digital Outlook and it record highest. I think with old analog I would never had seen over 1200 but this digital gauge reads so fast....Tim
2003 Extended Cab, 4x4 6.0 PowerStrokin 3.73 Limited Slip
WhonosWho is offline
Old 03-15-2005, 10:14 AM   #5 (permalink)
YODA's Avatar
My Photos: (14)
Just a quick reply here. Havent been around a while (new promotion / moving)
Anyway to put you mind at ease. Stock my 04 could hit 1425 towing. Dealer Doc said normal and dont worry AS LONG AS PROPER COOL DOWN IS FOLLOWED.
Now to that he said dont just watch the pyro. Give it a gould couple minutes after the pyro hits 400 (normal on my truck at idel) if you have ben running that hard.
These motors will take the heat for short peroids of time (less than 30 minutes)
Now having said that I put a DPPI [img]/ubbthreads/images/graemlins/biggrin.gif[/img] dual cat back exhaust on mine which cut the temp by about 100 to 200.
My limit sustained is 1250 to 1300 pulling grades etc.
Best advice is talk to your Doc and se what he says.
What I have found is the 6.0 runs about 100 to 150 hoter than my old 7.3 when towing.
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
YODA is offline
