Mechanics Help! Trans Service info - Diesel Forum - TheDieselStop.com
Old 11-16-2008, 12:40 AM   #1 (permalink)
How long does it take to service a 06 torqueshift in a PSD? I had mine serviced the other day and it only took the guy about 45 min. Was supposed to do a full fluid exchange via machine as well as change both filters. I can't find any evidence of any wrench even being on any of the bolts on the pan or the external filter housing. Any help would be appreciated!
Fandini is offline
Old 11-16-2008, 11:35 AM   #2 (permalink)
they usually dont even take that long, changing the filter in the pan is a pretty big waste. the inline one is a good idea though.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 11-16-2008, 11:44 AM   #3 (permalink)
I can do then in about 30mins or less with a BG machine. Its a very good idea to change the external filter.
83 F250 6.9 4 speed
04 F350 6.0l Crew cab,Sunroof,Leather,Heated seats,8ft bed,reflex liner,5th wheel hitch and gooseneck.. Bone stock.
My site motoxfarms.com
born2ride is offline
Old 11-18-2008, 01:16 PM   #4 (permalink)
JIM_C's Avatar
My Photos: (5)
Why do you say that? Is it because any metal fines wind up on the magnet and not in the filter?
I drained the pan and changed the bypass filter at 40k - the filter was dark but the fluid was still pink and not burnt-smelling. I have 60k now and was going to do it again to get another 8 quarts of fresh fluid in there. I was going to change the internal filter this time as well. Thoughts?
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto
JIM_C is offline
Old 11-18-2008, 08:36 PM   #5 (permalink)
its just a screen, so really unless you have a failure its not nessesary.
