Mercon LV vs SP - Diesel Forum - TheDieselStop.com
Old 11-13-2009, 10:49 PM   #1 (permalink)
Mercon LV vs SP
I stopped at the Ford dealer today to get a case of Mercon SP and was informed that just recently Ford announced that the New LV will be taking the place of SP in all Torqshift trans vehicles. The parts worker said the Mercon SP will be phased out as supply is exhausted. The price will be the same, for me it was $4.61 a quart.
Ljutic SS is offline
Old 11-14-2009, 01:54 AM   #2 (permalink)
hitecdan's Avatar
My Photos: (22)
To meet the performance demanded by Mercon LV, most products will need to be formulated with Group III oils, Ved added. "Based on Mercon LV's viscosity, shear stability and antioxidancy requirements, use of higher-end Group IIs, Group III and PAOs will be the best scenario." He said there seems to be adequate supply of Group IIIs to meet the volume needs, as the LV market develops; also, there will be less turnover of the fluid, since the transmission fill intervals will be so much longer.
Mercon LV joins Mercon V and Mercon SP as the only current Mercon products for conventionally shifted automatic transmissions. (There is also Mercon C, designed for CVTs).
"The goal with LV was to create a more robust fluid, even beyond that of Mercon V," Ved said. "We aren't yet replacing SP, which is used in our conventionally shifted five-speed and six-speed transmissions, but there is a significant amount of testing ongoing to replace SP with Mercon LV."
LUBE REPORT: Ford Unveils New Transmission Fluid
My html Version of the 6.0L Bible Now with 2005 Updates
$5 AIC
Born on date: Jan 20, 2003
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 4/15/2010)
The United States Constitution © 1791, All Right Reserved.
hitecdan is offline
Old 11-14-2009, 06:32 AM   #3 (permalink)
That article has been around for almost 3 years now. Lots of testing and decisions have been made since April 2007.
Old 11-14-2009, 01:15 PM   #4 (permalink)
MikeL46's Avatar
My Photos: (14)
From Ford Tech Service bulletin Sep/Oct 2009:
Untitled Document
Tech tips
Approval to Service ALL 5R110 Automatic Transmissions with MERCON® LV
Beginning immediately ALL (2003 to 2010 MY) 5R110 automatic transmissions can be serviced with MERCON® LV automatic transmission fluid in place of MERCON® SP.
Initially only the 2009/10MY 5R110 automatic transmissions were filled and serviced with MERCON® LV. In an effort to reduce complexity, Ford Motor Company is allowing all previous model year 5R110 automatic transmissions to be serviced with MERCON® LV automatic transmission fluid. This pertains to top off as well as fluid replacement. Mixing of MERCON® LV and MERCON® SP in the 5R110 transmission is acceptable. Extensive testing has been performed to insure there are no functional or durability concerns with the use of MERCON® LV in the 5R110 automatic transmission.
Vehicles affected are F-Series Super Duty trucks (including chassis cab, motorhome, LCF).
Motorcraft MERCON® LV is now available in three sizes:
Part Number: XT-10-QLVC - 1 quart
Part Number: XT-10-DLV - 55 gallon drum
Part Number: XT-10-BLV - Bulk
Further information can be found in the Workshop Manual, Section 307-1, Automatic Transmission
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-14-2009, 03:20 PM   #5 (permalink)
69cj's Avatar
Do you have the TSB number for reference at the dealership?
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 11-14-2009, 08:01 PM   #6 (permalink)
MikeL46's Avatar
My Photos: (14)
I don't.
Mike
MikeL46 is offline
Old 11-14-2009, 08:02 PM   #7 (permalink)
I will swing by the dealer on Mon. and get the TSB #
Old 11-16-2009, 01:49 PM   #8 (permalink)
Ford technician hotsheet september/october
Tech tips
approval to service all 5R110 automatic transmissions with Mercon LV
beginning immediatly all (2003 to 2010 MY) automatic transmissions can be serviced with Mercon LV automatic transmission fluid in place of Mercon SP. Mixing of Mercon LV and Mercon SP in the 5R110 transmission is acceptable.
Vehicles affected are F- series super duty trucks (including chassis cab, motorhome, LCF).
further information can be found in the workshop manual,section 307-1, automatic transmission.
