Old 09-09-2006, 04:50 PM   #1 (permalink)
Smiley1's Avatar
More power than normal?
This may be normal but I didn’t expect it. I was at a stop next to another rig (Chevy with trailer). Light turned green and I hit the gas. As the turbo spooled I broke traction pulling my 6K lb trailer. I just wasn’t expecting it. I kind of was embarrassed for a moment.
Do others experience this? So far I am quite happy with this truck.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 09-09-2006, 04:59 PM   #2 (permalink)
Re: More power than normal?
I've turned the tires over towing my 32' boat (13,000 lbs.) as the tires hit the large white line at the intersection. I adjusted the boat a little forward on the trailer and it won't do it anymore.
2008 Tundra Crew Max Limited 5.7
2004 F-250 CC Lariat FX4 6.0 PSD with 132K miles (traded)
boatingncst8fan is offline
Old 09-09-2006, 11:31 PM   #3 (permalink)
Do you have a weight distribution hitch? If you have transferred a little too much weight to the front suspension you can spin the tires. I did it once - just backed the weight distribution hitch chains down one link and no more tire spin.
06 F350 SC LB 4X4 FX4 Lariet 6.0 Torqshift, True Blue Clearcoat, tow command system. Toyo Mud-Terrain tires size 35/12.50//18 on stock wheels, Mag-Hytec rear differential cover, Bilstein shocks, and Alpine 9833 head unit, Kenwood Excellon speakers, and an Alpine V12 4 channel amp with 80 watts per channel RMS.
ronk54 is offline
Old 09-10-2006, 12:10 AM   #4 (permalink)
Smiley1's Avatar
That may be it. I do use a WDH but I dont crank it much at all as my trailer rides low in the back already (two links hanging). I also load as much weight to the front of the trailer as possible. I would guess that I would do fine without the WDH. Even with the trailer it puts you back in your seat when mashed. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Smiley1 is offline
