I bought my truck new in 04. I have an SCT SF3 Programmer and use the least aggressive program. For 8 yrs I have enjoyed about 20 MPG at 55-60 MPH on the highway with no towing or hauling load.
All of the sudden my mileage has dropped to 15 MPG at ONLY 55 MPG. The truck starts, accelerates, and otherwise seems to run just fine. There is no hesitation, smoking, etc. Boost readings seem OK, and there are no error codes present. Have not made any changes to vehicle in years.
I actually calculate MPG vs relying on computer.
Any thoughts, suggestions etc on what might be causing this?
Thanks much.
04 F350 Lariat, ExCab, SRW, 6.0, LOADED Shorty
SCT SF3, MBRP Turbo Back 409, Max AC Assist
DieselSite Coolant Filter, OilGuard Bypass Filter
Fumoto Drain Valve, HFCM Separator Drain Plug,
EGR Delete, 50 gal TransferFlow, Sliding Cargo Bed
ScanGauge II, GlowShift EGT, Boost, Fuel Pressure
Front Receiver, Warn 8000 lb (Draw Bar Mount)
WeatherGuard Lo-Siders, MacNeil Floor Liners
Galaxy DX95T 10 Meter w/ CB Mod, Wilson 5000
Kimber SS .45 cal UltraCarry w/ LaserMax!
Frame Mounted Safe,
Empty Weight with 80 Gal Fuel 8400 lbs
Have you had it into the Ford Dealer recently? Did they reflash your computer? I had a similar situation with my '05. Mileage dropped 20% after Ford did the "upgrade".
However, I have noticed that it just started running extremely rough at startup in 30 degree weather...smooths out in about 1 to 2 minutes. Wonder if this could be related to MPG problem.
Frame Mounted Safe,
If it is starting to run rough, that's a good sign that your ficm is starting to go bad. When it starts getting weak and doesn't give the injectors enough power, it'll cost mileage. When it has bad mileage, it then proceeds to running rough. My 04 went from 21 mpg to 12. No more than a month later it started running slightly rough right at start up. Now it is a b!tch to start. My FICM voltage is 37 volts when running. Should be no less than 46. Getting it rebuilt. We'll see what happens in a few days.
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 tuner, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
So far I have disconnected, charged, and load tested my batteries to find out that they are both in excellent shape. Interestingly I had to charge the batteries for about 3 hours each on the 25 amp setting to bring them to full charge according to my "smart" charger. At this point they both measured 12.6 volts under no load with a DVM.
I have also programmed my ScanGuage II to show 3 different FICM related voltages, including the main power of 47 to 49.5 volts . Tomorrow I will be monitoring those voltages as I start it up, as well as the charging volts when things have settled down. If charging volts (13.3 or so) are low, I will be installing a replacement higher amperage alternator.
This is a little premature, but I am already of the opinion that I might simply have clogged up fuel injectors. I have ordered the Hot Shot Diesel Duo....which I should probably use at 90,000 miles anyway. If my test tomorrow show any suspicious FICM voltages, I am going to order a tuned FICM from.......... FICM Repair.com - Your Source for FICM Repair
Frame Mounted Safe,
Make sure a brake caliper isn't hanging up or the A/C compressor clutch isn't frozen (inspect the belt for wear or shiny spots on pulleys). Low tire pressure is a killer also
Update - Upon starting today, the FICM main voltage started out at 47v, but after running for just a minute or so, it dropped and stayed at 27-31 volts. Alternator output voltage was 13.2 with some accessories running.
I have ordered tuned FICM and 100 amp alternator and wiring kit from FICMRepair.com, and the DUO additive package from LubricationSpecialists.com.
Will post results when all is installed.
Frame Mounted Safe,
I think we found your problem. It should hold that 47 ever after running for awhile.
Ty (Dukey)
It probably wouldn't hurt to run cleaner in the tank a few times to clean up the fuel side of the injectors and run your oil additive to clean up the oil side of the injectors, clear up any stiction issues. AR9100 seems to be the new product to use for stiction.
Also we are on winter blend diesel now so expect drops in mpg.
To the OP, best way to check that I've found is to get an I/R thermometer and check your rotor temps when you stop for fuel on a highway run. Just last weekend I found my left rear sticking and the temp was well over 400°.
The caliper itself was not sticking it was the pads in the slots on the caliper bracket that froze. Corrosion is a big issue in my area due to close proximity to salt water (nor do I drive on the beach).
Since this has been an ongoing issue in my case I make it a point to make the rounds and check the temps of my rotors while the truck is being refueled.
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 ESOF
A/C, T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2450 Hrs +/-, 90K Miles - No Major Probs
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade Blue Spring Upgrade
FP Gauge
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
I live by Salt water also. Just happen to have a couple of IR Thermometers, so I will do exactly what you suggested. However, I still think the problem is the FICM. Will post results later.
Frame Mounted Safe,
