My Boost is crap!!! - Page 2 - Diesel Forum - TheDieselStop.com
Old 04-09-2009, 01:46 PM   #16 (permalink)
All you need is a SCT tuner with custom tunes to turn the EGR function off. My truck will do the exact same thing with the valve unplugged. I have a transmission tune with ano HP added except the EGR valve turned off and am good to go.
2005 F350 6.0L CC Lariat
ciscofreak is offline
Old 04-10-2009, 09:54 AM   #17 (permalink)
Cisco,
yeah man I just got my SCT programer in tha mail yesterday. I am waiting on my custom tunes to be e-mailed to me. I hope this will work, I have talked to at least five different guy all over tha country and they all told me to call Innovation Diesel off tha est coast and get me some custom tunes. I had a bed run in with peformace diesel stuff before, I had bought some stuff (programer, exhaust) form a company outta TN called ETR Diesel performance. Man was that a mistake, I cancled my order and tha sorry low lifes would not give me my money back!!!! I finally had to get Visa to go after ther ass. I eventually got my funds back but took almost a month. So beware of ETR Diesel performace they are crooks!!!!!!! I will post another thred when i get my tunes and see what it does. Thanks for tha input thou.
David
engineman02 is offline
Old 11-09-2009, 12:47 PM   #18 (permalink)
do you know if the heads were machined? They are NOT TO BE MACHINED! the valvetrain is not adjustable, so if you shorten the heads you LENGTHEN the pushrods thus holding the valves slightly open.
hotshoe396 is offline
Old 11-09-2009, 10:08 PM   #19 (permalink)
It's absolutely fine to take up to .006 inches off without qurestion though people have taken .008 off without harm.
Old 11-10-2009, 12:02 AM   #20 (permalink)
if your custom tune doesent work check diesel fuel pressure,did heads ,studs and egr bypas on 04 and could only get 22 psi,filters new,idle fuel pressure was 55psi when under load would drop off to 30psi ,replaced pump and 28-39psi,,,,
1996 F350 CREW CAB,37"tires,2003 hpop,160CC injectors,electric fuel system.malery pressure reg.6.0 intercooler,sd bd turbo,sd 3 in intakes ,tw 4 pos. chip,gauges,tcc disconect,mod.e4od,rear detroit,20,000remote cooler,baja fiberglass body panels,stage 3 methanol...............
NORTHRIVER1 is offline
Old 11-10-2009, 12:08 AM   #21 (permalink)
oh yeh have done many head gasket jobs and machined over .08 with no valve train clearance issues,,,,,,only problems are northern dealer guys gouging block decks with roloc disks,even though they are trained not to do that....must be the flat rate times
Old 11-10-2009, 11:40 AM   #22 (permalink)
Come to find out, there is no such thing as a EPA limp mode on these trucks. It is the calibration from the Ford dealer that robbed my truck of power and fuel economy. There are a number of ways to fix the problem. 1. You can get a FICM off a 03 that has the good old strong running calibration and install it on your truck. The only down side with the early FICM's is that you cant get individual cylinder readings. It will only diagnose from the left bank to the right bank. 2. You can pull your FICM off your truck and send it to Innovative diesel out of maryland and let Eric recalibrate it. This will give you your power back and MPG!!! This will run you about 200 bucks. 3. There is another company that does it out of GA. There name escapes me right now but they only charge a little over a 100 bucks to do recalibrate it also.
Old 11-10-2009, 05:45 PM   #23 (permalink)
My guess is the vgt solenoid is stuck or won't go into the "3rd gear" I think there are 3 steps in the vgt...correct me if i'm wrong...Sounds like 1 and 2 are good, but 3 give you high boost at high rpm...basically like a tall 3rd gear.
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
http://www.youtube.com/watch?v=M2zEFb6bFLc - Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
Old 11-10-2009, 06:55 PM   #24 (permalink)
LocoMike's Avatar
Your VGT Turbo vanes can get stuck in almost any position. I suspect the vanes are stuck and you are building boost as exhaust flow increases but the vanes are (or the plate that turns them) is stuck.
Your turbo can easily be reconditioned for very little material cost and will love you for it.
I can send you a turbo guide or recondition procedure if you like.
Here is a pick of MY stuck vanes at 118K. Look closely at the rust shadows and you can see the position they were stuck in. I moved them after disassembly for the pic.
File Type: pdf How to_ Recondition your 6.0 VGT turbo - Powerstroke Nation.pdf (613.3 KB, 77 views)
LocoMike is offline
Old 11-12-2009, 01:21 PM   #25 (permalink)
Hey LocoMike,
Maybe I'm missing something, but I see in your PDF the International Parts to get, but not the actual procedure...Or does that come with the kit?
Old 11-12-2009, 01:35 PM   #26 (permalink)
24 psi is max boost on a 6.0 if the vgt and factory setting are correct this is per fords pced poowertrain control emmission diag manual
outlawpony is offline
Old 11-12-2009, 01:58 PM   #27 (permalink)
He stated he had a bullydog downloader, should be more than 21..
I
m hitting 38, granted its an 03 turbo, but he should still be getting more than 21 regardless
Old 11-19-2009, 09:34 AM   #28 (permalink)
my boost is back to where it was before just by installing a 03 FICM on my truck. I picked up a 03 turbo also but before i install it I am going to get my buddy that is a PSD tech to check it out the internals to ensure this thing is in good condition.
Old 11-19-2009, 09:51 AM   #29 (permalink)
"I barely hit 20 PSI until about 60 MPH "
And your problem is what ????
As long as it pulls great why are you expecting more? The whole purpose of the VGT setup is to give you sufficient boost for the load on the engine - and not a pound more. FYI I get exactly the same as you - 20 - 21 accelerating to 60 - then it settles down to 10 or so. If I put it on cruise I can watch the boost guage go up and down as I go up and down grades - and the tach stays at the same RPM. This is EXACTLY as it is supposed to be. Sounds to me like your chasing a phantom here.
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
Old 11-19-2009, 12:28 PM   #30 (permalink)
CAMPINGTOM's Avatar
I have never heard this. Mine hits 28psi regularly.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, EGR Delete, Insight Monitor, SCT X3 (Tuned by Innovative)
Stock head bolts, injectors and turbo
CAMPINGTOM is offline
