My HFCM is leaking like a sieve...........any opinions, PLEASE?!? - Diesel Forum - TheDieselStop.com
Old 03-07-2005, 02:34 PM   #1 (permalink)
The title says it all....my HFCM is leaking rather badly---started this weekend. [img]/ubbthreads/images/graemlins/crazy.gif[/img] 29K on the clock and no real problems until this......it leaks badly enough that if I park the truck overnight, there is a circle of fuel on the ground about 8-10 inches in diameter......each night. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
I have checked the filter caps and they look clean as a whistle, I also rechecked the torque of the fuel drain plug and it is TIGHT, as well as the fuel lines looking clean and tight.
I am at a loss, has anyone else had a problem with their HFCM leaking. This leak, unlike my rear main (which is more like an oil coating), is REALLY A LEAK!!! [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Any thing I can do besides going to the stealer? Any help or opinions would be appreciated. [img]/ubbthreads/images/graemlins/blush.gif[/img]
<font color="blue">"Sic Semper Tyrannis" </font>
<font color="red"> 2003 King Ranch F-350 FX4 Crew Cab SRW SWB 6-OH!</font>
woodsracer is offline
Old 03-07-2005, 02:55 PM   #2 (permalink)
Re: My HFCM is leaking like a sieve...........any opinions, PLEASE?!?
Not sure it will help, but I had a problem once:
First time I drained my HFCM, I backed the plug out part way, let it drain, then screwed it back in. It leaked.
My problem was that in doing a partial removal and reinstall of the plug, I pinched and cut the o-ring. I took it all the way out, and ensured it went back in properly - leak stopped. I've since replaced the o-ring too.
Now, I always remove, inspect, and clean the plug when I drain the HFCM.
Good luck with yours.
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 03-07-2005, 09:19 PM   #3 (permalink)
Had the same problem, try taking the plug out cleaning and re-installing, it solved my leak right away.
2010 F350 6.4L XLT CC Off Road, 4X4,
Gibbsey is offline
Old 03-07-2005, 09:22 PM   #4 (permalink)
POS
That's your only choice - take it apart, clean it a bit, then carefully put it back together. I bet your pinching an o-ring.
<font color="red"> WIX filters at </font><font color="blue">www.fleetfilter.com</font>
POS is offline
Old 03-08-2005, 06:44 AM   #5 (permalink)
Same here, pinched/cut O-ring!!
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
Old 03-08-2005, 09:52 AM   #6 (permalink)
Been here, done that. Replace the O ring.
Tincan
<font color="red">[b] 2003 F250
6.0 PSD XLT, 4x4 SC FX4 LT265's 3:73 LS/Torqshift
LineX Bedliner Hog Catback Exhaust Virtual Billet Grill Tranny tune by ID
<font color="blue">05/05/03 Build date
<font color="blue"> Anchors Aweigh
tincan is offline
Old 03-08-2005, 01:15 PM   #7 (permalink)
Thanks for the responses. Funny thing is that it has been about 5000 miles since I changed the filters and drained it all........and it took THIS LONG to start leaking?!? [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] I'll give her a shot before I go into work and see if I can't get it straightened out.
BTW, does anyone know the correct O-ring replacement size if I need another? [img]/ubbthreads/images/graemlins/blush.gif[/img]
Thanks again......I appreciate it!
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 03-08-2005, 01:31 PM   #8 (permalink)
Not sure on the size. I tried getting it from Ford, and had to buy the plug with the o-ring. It wasn't too much, but can't remember the exact price. Now, I've got an extra plug just in case (with a cut o-ring) [img]/ubbthreads/images/graemlins/cool.gif[/img]
Built: 11/03/03
4x4Mark is offline
Old 03-08-2005, 02:50 PM   #9 (permalink)
TexasTruck's Avatar
My Photos: (13)
You say that you really tightened the plug, maybe you overtighten it and now it cracked, that's been known to happen to the casting...
Just my .02
Scott
2008 Silver F250 FX4 6.4
ICON / OUO / Line X / Viair / Air Horns / BMF / Toyo / GOS harness / Custom Driveline
"A problem is an opportunity in work clothes"
TexasTruck is offline
Old 03-09-2005, 02:59 AM   #10 (permalink)
Just my .02
Scott
Scott, that's an idea, BUT I can assure you that that I didn't overtighten it. I "snugged" it tight. I tighten screws in aluminum all the time when working on my race quad so I have a "handle" on how not to over tighten in aluminum. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
I betcha anything that I cut that darned O-ring! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] Just truly odd that it's taken THIS LONG to start to leak. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 03-09-2005, 06:32 AM   #11 (permalink)
Just my .02
Scott
Don't even go there!
Old 03-09-2005, 07:44 AM   #12 (permalink)
TexasTruck's Avatar
My Photos: (13)
woodsracer,
Yeah that's strange... I hate leaks... Liquids find their way out anyway they can [img]/ubbthreads/images/graemlins/confused.gif[/img]
As others said already, I take mine completely out and wipe the plug and openning out after it stops.
Scott
Old 03-09-2005, 12:23 PM   #13 (permalink)
Thanks for the heads up on that one. I have drained it twice without removing the plug completely. Next time I will completely remove it to avoid cutting the o-ring. I love this site! Thanks guys.
maps
Just my 2¢ Take it for what it's worth!
________________________________
2003 F250 4x4 XLT Supercab SB 6.0L/TorqShift, FX4, Add On's: 285/75/16 BFG AT's, MBRP turbo back, Dieselsite coolant filter, Isspro gauges on the A-pilar, remote start, RhinoLiner, Prodigy, Husky floor liners, Husky mud flaps, Firestone Ride Rites #2071, fumoto valve, Weathertech Weatherflectors
maps6874 is offline
Old 03-09-2005, 05:25 PM   #14 (permalink)
As I mentioned in another post about replacing oil filter O-Rings,
I cut the O-Ring on the frame rail mounted HFCM housing and was fortunate enough to see it and changed it before it caused a leak.
Did I remember to say: I really hate O-Rings...
I lost a motorcycle road race many years ago because of a brake system
leak caused by a lousy .50c O-Ring!
I too have learned everything I know about my Diesel on this site.
It was very satisfying to prove my know-it-all brother-in-law when he tried to tell me about "My Junk Diesel Engine" [img]/ubbthreads/images/graemlins/confused.gif[/img]
Regards
JR44
2003, F-250, 6.0L PSD, Torqueshift, CrewCab, XLT,FX4,Short Bed, All Black Sport Model, Sunroof, Line-X Bed Liner, AFE Stage1 Pro-Guard 7, DPPI/MBRP T-304 Stainless Turbo-Back Exhaust, complete with CNC machined collar!
Banks Tecni-Cooler, Front,Rear Diff & 5R110 Mag-Hytec Pans, AutoMeter Cobalt Boost,EGT,Trans Gauges on A-Pillar, Bridgestone 285 Revo's, Bilsteins,SSBC V8 BRAKE CALIPERS, POWERSLOT CRYO ROTORS, Lund Smoke Bug Shield and Weathertech's AeroVisors on all windows. 16YR N.R.A. member, 14YR D.U. member, 10YR N.W.T.F. member. 5YR Delta Waterfowl member. www.rntcalls.com
warrenpouyer is offline
