My Truck is PUKING! - Diesel Forum - TheDieselStop.com
Old 12-26-2009, 06:00 PM   #1 (permalink)
SickStroke6.0's Avatar
My Truck is PUKING!
Hey guys, is this severe? I still have an extended warranty, but I just haven't had time to take it in. So does this need immediate attention, or can it wait a week or two?
http://www.youtube.com/watch?v=nWYrKpcb18I
2003 Ford F-250 6.0l Powerstroke CC SB Lariat FX4
SCT Xcalibrator2, ARP Head Studs, RCD EGR Fix, High Idle Mod, ZooDad Mod
2.5" Leveling Kit, Icon Signature Series, 18x9 Chrome XD Badlands, 325/60/18 Nitto Terra Grapplers
SickStroke6.0 is offline
Old 12-27-2009, 12:00 AM   #2 (permalink)
joshr33's Avatar
First off, what color is the coolant in the degas bottle, pretty much clear or does it look like chocolate milk? If it is still clear do you have the degas bottle filled past the "min" line while not running? if it is past the min line then expect it to puke until it gets itself down to the mark. Clear, not filled past the fill line then the best thing to do is go have it checked as there is a multitude of things that can be going wrong and can get pretty costly with replacing parts until it stops... Now if it looks like chocolate milk then you more than likely have a bad oil cooler which is pretty common on these trucks due to the design.
I guess the answer to your question is if it's clear then you can wait a bit (keep an eye on the coolant level), if it's chicolate milk then you need to get it in for repairs as soon as you can as the longer you wait the more sever the repairs will be.
My .02
JR
Oh and you said it's still under warranty... If it's the truck in your sig seems to me the 5/100,000 warranty is up unless you have an added warranty???
joshr33 is offline
Old 12-27-2009, 05:56 PM   #3 (permalink)
My .02
JR
Well the coolant is below the minimum fill line, and its still pretty clear, so what does that mean?
And I bought an extended warranty from Ford to 200,000 miles.
Old 12-27-2009, 07:37 PM   #4 (permalink)
What would cause the 'chocolate milk' condition? Some sort of contamination, obviously....
2008 F-350 Lariat CC LWB 6.4 PSD, DRW, FX-4 4x4, 4:10 born 06/07 K&N FIPK
and
2004 F-350 Lariat CC LWB 6.0 PSD, DRW, FX-4 4x4, 4:10 Born 06/04 bought BRAND NEW on 10/26/04 Woo HOOOO This truck ROCKS!!! No mods yet,and it seems none NEEDED!! Replaced transmission @ 37k miles and EGR valve @ 58k miles : 92,000 miles as of Nov 2009
and
1996 F-250 SC 7.3 PSD, SRW, 4x4, 4:10 gears, bought new in May 96, TyMar Intake(on@150,000),Updated Turbo inlet hoses and breather assy,TrueCool 24,000 Tranny Cooler, Diamond Eye DP/Exhaust,Eviscerated Kitty,FPR Shimmed w/BB,Autometer z-series guages (boost, Tranny Temp, post turbo Pyrometer).Replaced Water pump @ 100,000.Rebuilt Tranny @ 140,000.Replaced GPR and Glowplugs at 159,000.Replaced brake vacuum pump 162,500.StanCor Heavy Duty GPR,4R100 tranny pan.Replaced starter @ 185000 miles : 225,000 miles as of Jan 2012
Powerstroke3302 is offline
Old 12-27-2009, 08:43 PM   #5 (permalink)
Supporting Member
Oil/Coolant temps?
Any idea what your oil and coolant temps are?
Search this site for failed oil coolers and you'll get an idea of some of the symptoms.
Could be your oil cooler is flash boiling your coolant and who knows what color that might be when it gets blown out your degas bottle.
mlwest is offline
Old 12-27-2009, 11:24 PM   #6 (permalink)
joshr33's Avatar
If coolant is below the minimum fill line and still puking you need to take it in and get it diagnosed. Can be anything from a bad degas cap to oil cooler, egr cooler, head gasket, and anything in between... just get it checked before you have bigger issues arise.
And you will know once the oil cooler lets go as your oil and coolant will start to mix thus causing the chocolate milk syndrome...
JR
joshr33 is offline
Old 12-28-2009, 12:58 AM   #7 (permalink)
i would get it in as soon as possible. you never know when it might make a turn for the worse and leave you stranded and/or cause extensive damage. good luck and thank goodness you are still under waranty.
iforge03 is offline
Old 12-28-2009, 01:41 AM   #8 (permalink)
prohydroracer's Avatar
Oil in the coolant from the oil cooler failing
2004 F-250 Lariat Ex-Cab Long Box
  • ARP Stud's
  • MBRP 4" Turbo Back
  • Oil and Coolant Bypass Filters
  • SCT w/Custom Tunes
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight monitors EOT, ECT, Tranny Temp
  • Full Security with Remote Start
  • Anti Hi-Jack Device by GLOCK!
prohydroracer is offline
Old 12-28-2009, 09:06 AM   #9 (permalink)
Ha you have no idea! I've already broke even with what I paid for the warranty when I had to get all 8 injectors replaced. And now maybe another possible $4000 that Ford is gonna have to fork out to fix my truck Gotta love it
Old 12-28-2009, 11:26 AM   #10 (permalink)
Before you panic you might want to invest in the new style Degas cap used on later PSD's that seals better. The early caps are prone to leaking, my 03 had similar staining on the hood lining when I bought mine and I had the seller pay for a new cap...it's never puked yet even while towing on a real hot day. If the cap doesn't solve it you'll probably be looking at a new oil cooler replacement and a new coolant filter at the very minimum.
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is offline
Old 12-28-2009, 12:43 PM   #11 (permalink)
69cj's Avatar
6.0's didn't come from the factory with coolant filters! He should however seriously consider installing one. Great investment for the price.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 12-28-2009, 04:21 PM   #12 (permalink)
Ha I'm not panicking at all. Honestly, now, I want it to be a failed EGR cooler or blown headgaskets! I called my diesel tech today, and before I even said anything he was talking about Studs! He said, if it is something wrong, he will install head studs and an EGR cooler at no cost if I supply the parts Turns out, he works at a diesel shop nearby that specifically works on modifying the 6.0ls
So, any way I can guarantee its a failed cooler or blown headgaskets? I had something pour out of my exhaust pipe today when i put her in a powerstance, a minute after I cranked her up. It was kind of a milky/clear substance. It let enough out in ten seconds that you could easily notice it on gravel. Do you think it's coolant?
Old 12-28-2009, 04:39 PM   #13 (permalink)
I assumed anyone here that has read anything about 6.0 puking problems realizes none of these trucks came with a coolant filter and they are needed for longevity. That's why I said 'replacement' oil cooler and 'new' coolant filter because it's not a replacement; it's new.
Thanks for the semantics lesson though and I'll be more clear next time.
2Tight is offline
Old 12-28-2009, 04:55 PM   #14 (permalink)
Old 12-28-2009, 06:58 PM   #15 (permalink)
69cj's Avatar
Agreed, I put a new coolant filter on my truck every january. Have had a coolant filter on the truck since new at 3,000 miles.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
