My Turn - Diesel Forum - TheDieselStop.com
Old 11-18-2009, 09:09 PM   #1 (permalink)
Btravelen's Avatar
My Turn
Warranty Head Gaskets and Bedplate reseal. I shared my concern with the tech regarding head 'flatness'. He said he hasn't found many, if any, heads that were out of spec. I said that I've read that there are a fair number of repeat head gasket repairs due to warping that is not found during the initial repair. He said that Ford reports that +/- 90% of the heads that are warranted are not bad.
He's willing to install studs, but I've read a few threads about blown gaskets with studs installed, resulting likely from heads that were warped and not checked before replacement the first time......
I was assured the procedure for checking the heads for flatness will be followed.
To be continued....
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
Btravelen is offline
