need help asap - Diesel Forum - TheDieselStop.com
Old 07-24-2009, 09:48 AM   #1 (permalink)
Spoolin'6.0's Avatar
Send a message via AIM to Spoolin'6.0
need help asap
so yesterday while my 03 6.0 was idleing it all of a sudden started skipping my first thought was injectors i call my as*hole dealer and they told me " well you know those motors are noted for having problems and it could be a hundred things i cant help you with out putting it on my computer it could be injectors, or the FCIM or your erg valve is stuck." so yea thanks for nothing. well i ruled out the erg cause i can still hear it open and close throuhg the exhaust and as for the injectors i am as we steak trying to see about them but any help as to othe rpossabilitys would be greatful the strange things is i get no smoke at all and i really havent lost any power
D&W DIESEL PERFORMANCE
DIESEL TECH
ELITE DIESEL ENGINEERING
SCT
TS PERFORMANCE
MBRP
BULLY DOG
AIRAID
Spoolin'6.0 is offline
Old 07-24-2009, 10:04 AM   #2 (permalink)
Your dealer told you the truth, without running a diagnostic check you can only guess or you can throw parts at it until it runs good.
Ljutic SS is offline
Old 07-24-2009, 10:35 AM   #3 (permalink)
I Second That And All The Parts You Are Just Throwing At It (in The Dark) Most Are Expensive And Can Not Be Taken Back Hey But Its You Money And Chances Are You Will Still Have To Take It Back To That (what Did You Call That Dealer) He Is There To Help If He Dont They Are Thousands Of Other Ford Dealers All Over This Nation
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline
Old 07-24-2009, 12:14 PM   #4 (permalink)
everything revolves around money and money is gonna have to be spent i just dont understand how guys that work on these things could have no idea about what it could be i mean come on this truck is deff. no under warrenty so any and all work will be done by me but these new fu*king electronic engines suck everything has to be done with a computer but i guess while i'm gonna hahve the motor apart i'll do my egr cooler (ha ha see ya later) and my studs but still i dont have much faith in their computer tellin me anything so any and all input would be gratefull
DIESEL TECH
SCT
TS PERFORMANCE
MBRP
BULLY DOG
AIRAID
Old 07-24-2009, 12:59 PM   #5 (permalink)
WE REALLY ENJOY YOUR COLORFUL LANGUAGE DO YOU KNOW WHATS WRONG WITH YOUR TRUCK AT THIS POINT THEY DONT EITHER WITHOUT SCANNING
JOHN 3:16
timbo2 is offline
Old 07-24-2009, 01:18 PM   #6 (permalink)
OT
OT's Avatar
S..curious..when u say eng. skipping..does that mean..sounds like its missing/not running on all 8/rough idle? No smoke..power ok, but started doing this yesterday. Not intermittant, but skips (miss?)is now full time?
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 07-24-2009, 01:24 PM   #7 (permalink)
InetDev's Avatar
You may be interested in picking up an OBDII monitoring device (AutoTap - OBDII Diagnostic Scanner is the one I use). Lets you see codes, reset them, and VIEW IN REAL TIME hundreds of monitored things such as any misfires, sensor levels, and operating conditions. Well worth it to invest the $200 if you plan to keep the truck long term as a DIY'er.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
InetDev is offline
Old 07-24-2009, 02:44 PM   #8 (permalink)
Start with a EGR valve, if it runs the same then put a new FICM in. If it's still the same try replacing an injector 1 at a time. P.S. I started having this pain in my mid torso and I refuse to go these crook doctors, any of you guys have an idea whats going on?
Old 07-24-2009, 04:48 PM   #9 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Auto enginuity will let you buzz test injectors, check the ficm and diagnose just about everything. Its $400 ish but the best for our trucks. When you consider $300+ to diagnose a problem from ford it is very reasonable
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 07-24-2009, 05:55 PM   #10 (permalink)
the dealer told me it was most likely the egr valve but i can hear it opening and closeing throhg the exhaust and yes it sounds like it isnt running on all 8 and it is doing it constanly my thouhgts are the FCIM or an injector(s) what misleads me is that there are no codes which to me means it is probably a mechanical issue not electrical and i have no smoke and a very little loss of power not really enough to say so
DIESEL TECH
SCT
TS PERFORMANCE
MBRP
BULLY DOG
AIRAID
Old 07-24-2009, 06:53 PM   #11 (permalink)
InetDev's Avatar
Same symptoms for me. It appears to be the EGR valve. Having one shipped to install tomorrow.
InetDev is offline
Old 07-24-2009, 06:58 PM   #12 (permalink)
OT
OT's Avatar
S..what happens if u reset pcm to stock running program?
OT is offline
Old 07-24-2009, 10:15 PM   #13 (permalink)
Smiley1's Avatar
"IF YOUR NOT LIVING LIFE ON THE EDGE, YOUR TAKING UP TO MUCH SPACE"
If your living on the edge all someone has to do is give you a little nudge and over the edge you go. More space for me
Like everyone said, you really need to get it scanned. Your EGR valve may not be openning and closing all the way which may make things goofy. Its free to check and you have nothing to lose.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
