need help reading trouble codes - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-29-2007, 05:56 PM Thread Starter
It is a 2004 f-350 6.0 40k mi and I am getting a p1000 obd reset(dl) and a p0603 ICM KAM (dl) code. I got these codes off of my bully dog triple power pup. The check guage light is flashing and the tow haul light is flashing. Thanks for the help guys [img]/ubbthreads/images/graemlins/shrug.gif[/img]
jebsurf is offline
post #2 of 3 (permalink) Old 01-29-2007, 10:01 PM
Banned
Re: need help reading trouble codes
P1000 isn't really a code, as such.... it is simply a way for the PCM to tell us that not all of the emissions monitors have completed and it isn't sure if there may be a code coming.... P0603 tells us that the Keep Alive Memory power to the PCM has been recently "disturbed" (some tuners do this regularly, I believe). Any time codes are cleared (clearing KAM will do this), a P1000 will be set in memory.
For your other concerns, you will have to address the modules involved... those would be the HEC and the TBC modules. You will need a scan tool capable of communicating with proprietary modules.... ermmmmm, you did check the gauges, right?
GrampyJim is offline
post #3 of 3 (permalink) Old 01-30-2007, 09:05 AM Thread Starter
Thanks for the help! Also the trans temp did not seem like it was working.I guess the best bet is to just take it 2 the dealer. [img]/ubbthreads/images/graemlins/smile.gif[/img]
jebsurf is offline
