Need help with steering problem - Diesel Forum - TheDieselStop.com
Old 06-26-2009, 05:03 AM   #1 (permalink)
jello's Avatar
Over the last week my truck has developed some steering issues.
First I went to turn left and when I straightened out the truck was pulling hard to the left.
Then when I turned right it wanted to keep pulling right. Sometimes I'll be going down the road very slow speed and it goes from left to right like I'm driving in ruts.
I did a search on a few forums and thought maybe it's the valve in the gearbox. So I've been driving it until it does it more consistently so I can figure out for sure what it is.
A couple of days ago I noticed that my brake pedal would kick back, and now the power steering pump is whining, but not all the time.
So do I have a bad pump? Bad steering box? Or bad Hydroboost?
How do I test these?
2003 6.0 King Ranch, 6" lift, 37" M/T's, SCT, Lunar gauges, 4" MBRP Turbo back.
jello is offline
Old 06-26-2009, 09:58 PM   #2 (permalink)
I seem to have the same issue, any luck finding the problem? I just replaced all of my power steering lines and am sure there is no air in the lines.
themedic is offline
Old 06-30-2009, 07:23 PM   #3 (permalink)
Check the (relatively) easy and (relatively) inexpensive things first:
- tie rod ends
- upper and lower ball joints
- drag link joints
Raise the vehicle on jack stands via the frame or suspension, so there is no load on the tires when you check these items. If any are loose, they can cause steering funnies.
If all are good, then suspect the hydraulic system. Check the fluid level in the reservoir. Then listen for steering pump noise while idling, and then listen for noise while turning the steering wheel from one full lock to the other. Do all this with the front tires off the ground. Last, check the pump and hoses for leaks. If any leaks, these need to be corrected with new lines or new pump or new gearbox seals. If any noises, fill reservoir to proper level and retest. If still noise, pump likely needs replacing.
In my experience, replacing a gearbox is very unusal. The input and sector shaft seals can be replaced in most cases.
2003 F-250 XLT CC SB 6.0L 6sp 2WD 3.73 open diff, cab lights, 6 disc, camper pkg, spare tire, sliding rr wdo, hitch rcvr, lighted TTT mirrors, security group, black/silver, ordered 12/17/02, built 2/13/03 13:56, delivered 2/19/03
2004 Cardinal T31BH travel trailer
1997 Lund 1700 Pro Sport, red over tan, 90HP Honda 4 stroke, 9.9HP Honda 4 stroke, 40 lb. Minn Kota bow mount
chassis is offline
Old 07-03-2009, 09:12 PM   #4 (permalink)
MDKLES5's Avatar
Just Had Mine Fixed
I finally had enough and took mine (2006 F350 SD 6.0 4x4) to the dealer. "stealer"
Had the Hydro-boost replaced and the steering gear replaced. After all wheel alignment, it was over $2K My truck had just over 41K miles on it.
MDKLES5 is offline
Old 07-05-2009, 06:31 PM   #5 (permalink)
had problem like that with my truck check front axle joints for stuck joint pulls wheel left than right check joints than turn joint and check again
2006 f250 6.0 is offline
