This issue is becoming extremely dangerous. First off, the truck is a 2003 Excursion with the 6.0L with about 59K miles. They just replaced the center section of the turbo, but I had the issue before they did that as well.
The truck will surge while parked and idling, sometimes even stalling completely. It will also surge while stopped at a stop light (very dangerous if you are not expecting it) and has even started surging while driving and not on the accelerator. I took it to Ford a month or so ago and they could not duplicate nor could they see any codes. It actually surged extremely bad right before I turned into the dealership to drop it off, so I can't imagine why they could not find any codes. I do not want to waste the time to bring it in again unless I can ask them if they have checked specific items.
Sooooo, what could the issue be? EGR valve? ICP sensor? FYI, they replaced the ICP sensor about 4-5 months ago. Could it be bad again?
Any help would be greatly appreciated. I hate not be able to trust the truck, especially since this is my wife's truck and she carries our 2 boys around.
Mike 2003 X LTD,6.0L,Torqshift,4x2 (wife's toy) Autometer Z-series Tranny/Boost/Pyro in Under-dash pod Hellwig Rear Anti-sway bar Stull Billet Grill AFE Intake w/ Proguard-7 Magnaflow XL 4" Turbo Back Exhaust
my 03 pick up just started a simm surge.
sometimes:
at idle
light part throttle
intermittently on highway.
its starting to be not fun.
engine light is on , do not know code yet .sorry.
ps> what and where is the ICP sensor ?
thanks , sparkey
Stock 03 250 6.0 SD 2door 4x4 p/u
6.0 June 03 Build Date
92,000 miles
E-017 flash
5" Tail Pipe +Muff Delete , otherwise Stock
AND
2000 f350 7.3 ccab 4x4 , nice BIG truck that lumbers right along. Only 100,000 miles on it.
thanks , sparkey
ICP sensor= Injection Control Pressure sensor it reads the psi of your high pressure oil system..
It is under the turbo on the driver's side, in the HPOP cover.. And it is a pain in the backside to get to and change on the 03 and early 04 models. Thankfully, there is a write up in the 6.0 FAQ that tells you how to change it on an 03.....
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
*************************Thank you guys, a big help . very helpfull to be prepared.sparkey.
92,000 miles
E-017 flash
AND
I posted in another thread. My problem ended up being the engine wire harness. There was a short somewhere, so they replaced the entire harness and it fixed the problem. I had the ICP replaced about 6 months prior. If changing the ICP does not help, try the harness.
