Need a little help! - Diesel Forum - TheDieselStop.com
Old 03-18-2009, 09:53 AM   #1 (permalink)
Djanzen's Avatar
Need a little help!
Yesterday morning driving home from work I stopped at a red light and i noticed that my truck was missing. i drove it the one block to my house and let it idle while i looked at the codes with my outlook monitor. it had codes p0275,p2285. looked then up inside one is #5 cylinder balance power and the other is Injector control pressure senor circuit low. the miss would go away as soon as the engine rpm where increased. so i went to work last night and buy the time i arrived the truck was running like crap. i took it in the shop and looked at the codes again, this time there was p0263,p0269,p0275,p0360,p2285,u3560. # 1,3,5cylinders.
when i leave the truck running for about ten minutes it almost dies several times and has no power, it does not knock or make any noises just runs like crap. also noticed that the alternator was so hot that i almost burnt my hand on it! I unhooked the alt. has anyone ever heard of this before? I need a little help as i am 500 miles from home at work and need this truck to drive home in six days!
thanks in advance for any help
Dean Janzen
2003 F250 Larait Grey/Black 3.5" lift 33" tires Bully Dog Tridog with Outlook monitor MBRP 4" ex. KC sunshine out front
Djanzen is offline
Old 03-18-2009, 10:06 AM   #2 (permalink)
Had the hot alternator problem - Alternator was dying so I'm replacing it - same symptoms rough running unless I charged up the batteries on a charger - then ran smooth. I don't have a scanner (yet) so I can't help you with the codes - but from what I have read on this site. low battery/alt voltage screws with the electronics and injector firing - may be others can chime in with better advice - mine is - charge the batteries with a charger and see if the problem goes away - if it does - like mine did - you're looking at a new alternator.
GOOD LUCK !!! - lets us know how it turns out
RcGreg 2006 F350 Dually 4X4 6.0L with Tommy Gate - looking for heated seats.
rcgreg is offline
Old 03-18-2009, 05:56 PM   #3 (permalink)
Djanzen's Avatar
bump.
Djanzen is offline
Old 03-21-2009, 10:17 AM   #4 (permalink)
Djanzen's Avatar
So a replaced the alternator and all the electrical codes went away and changed the fuel filters. good thing? no,the truck starts and runs fine when cold but as soon as it warms up it run rough a little smoke out the exhaust has very low power. when you rev it up its a dog until about 1500 rpm then it takes off. i took it for a test drive around the block and when you get it over 1500 the thing has all the power that it had before. but if you let it come down to idle it will stall and not restart until the engine is cold again. then it will fire right up like there is nothing wrong. what the f--- is going on and in two days i need to drive 500 miles home with it can someone give me an idea of what to look at.
Djanzen is offline
Old 03-21-2009, 06:13 PM   #5 (permalink)
Djanzen's Avatar
*** nobody can give me any ideas
Djanzen is offline
Old 03-21-2009, 07:26 PM   #6 (permalink)
still getting the codes? probly and injector leaking compression into the fuel system.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
