Neep Help ASAP.. 6.0 Problems... - Diesel Forum - TheDieselStop.com
Old 03-22-2009, 03:31 AM   #1 (permalink)
Mad Max's Avatar
I scanned a friends 04 6.0 tonight and the HP Oil Pressure is dropping off like a rock as soon as the go pedal is hit. The pressure hits about 3000 PSI for about 2 to 3 seconds and then drops to about 1000 PSI.
The truck is also having a hard start problem. After the truck sits for a while it will not build HP pressure until it cranks for a long time. It finally builds enough pressure to start after about 20 to 30 seconds of cranking.
We also checked the low pressure oil and we are only seeing about 4 to 5 PSI at idle and 40 PSI above idle. Is this normal for a 6.0???
No knowing the 6.0 like I know the 7.3 I am taking a SWAG that it could be the HPO Reg O-Rings or the HPO Regulator. This truck has 513K on it and still rides and drive great.
This truck needs to get back on the road ASAP. It is used as the main income for a friend of mine and it loaded and ready to go as soon as we get the problem fixed.
Thanks,
Barry
If you live in AZ come join us at Arizona Powerstroke Group... Click here
http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 BTS Trans / Termys / Swamps 200/30 AA Injectors / Swamps IDM / GT38R BB Turbo / AFE Stage 2 / DP/ Evans Coolant, ART Rotors / Dynatrac Spin Free HD Front Hubs, 4 inch Stainless Exhaust, Auto Meter Cobalt Gauges.
Mad Max is offline
Old 03-22-2009, 06:03 AM   #2 (permalink)
RatherBNtheWoods's Avatar
I'm going to say that 4-5PSI for lube oil pressure is not good or normal. I believe I would follow that path, first by confirming it is only 4-5 then find out why. If it is that low, that may not be enough pressure/flow to keep oil in the HPOP reservoir, so the HPOP can't make good pressure.
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 03-22-2009, 09:41 AM   #3 (permalink)
Per the 6.0 Bible, oil pressure from pump is regulated to 75 psi by a oil pressure regulator located just below the oil pump. The regulator may be stuck open, pump may be bad ETC.
I would look at look at oil pressure as stated above.
Roy
2005 Limited, 6.0L PSD, 4X2, Mineral Gray, 3.73 LS. Excursion Build date 02-08-05 6.0L 2005MY Engine Build date 01-03-05 Huntsville, Ala.
2005 50th anniversary Thunderbird Red with all
options except hardtop.
Old Ride: 2003 Excursion 6.0 L March 2003 Build 73,000 with no significant issues.
RoyC is offline
Old 03-22-2009, 01:10 PM   #4 (permalink)
Mad Max's Avatar
At what RPM is the 75PSI at???
Mad Max is offline
Old 03-22-2009, 02:34 PM   #5 (permalink)
sounds like you have a high pressure oil leak... if its still under warrenty get it into a dealer and have them fix it. being that it still starts its probably just a dummy plug in one of the oil rails.
painsonlyapulse is offline
Old 03-22-2009, 06:31 PM   #6 (permalink)
Mad Max's Avatar
It has 513K miles so no warranty... He is checking for leaks under the valve cover...
Mad Max is offline
Old 03-24-2009, 01:32 PM   #7 (permalink)
JAKE8842's Avatar
Possible it is a low pressure oil problem but first thing i would check is the hpop. Very common for the plug to blow out of the side of it....
JAKE8842 is offline
Old 03-26-2009, 10:07 PM   #8 (permalink)
How much is it to replace the oil pump??? For jsut the parts
manitoba-rancher is offline
Old 03-26-2009, 10:15 PM   #9 (permalink)
Minumum oil pressure specifications from AllData
At operating temperature:
12 PSI @ 700rpm
24 PSI @ 1200rpm
45 PSI @ 1800rpm
If that was an accurate reading of your oil pressure than i would start diagnosing why your base oil pressure is so low...
2002 F350 CC SB Lariat 7.3 4x4 3.73 LS
Torredor Red, Viper 5701
md18 is offline
Old 03-26-2009, 10:54 PM   #10 (permalink)
Texascadillac42's Avatar
My Photos: (10)
I just went through this exact same problem with an 04 6.0L. LPO system was only registering 5-10psi at cold high idle, and basically 0 at hot idle. Turned out to be the ball that is pressed into the side of the HPOP. I put in a new HPOP and everything was fine. Hard starts went away, and more importantly, the low pressure oil went way back up. 30psi at hot idle, 60-65 running down the road, and 60psi at cold idle.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
