New 6.0 owner - Diesel Forum - TheDieselStop.com
Old 12-01-2007, 12:03 AM   #1 (permalink)
New 6.0 owner
Just bought a 04 Excursion with a 6.0 in it. I've been reading a lot about problems. What should I be looking for?
04 Excursion 6.0 4X4
Hellwig rear anti sway bar and Roadmaster active suspension system
96 F250 7.3
Removed superchip after stalling issues
jeffe7572 is offline
Old 12-01-2007, 12:34 AM   #2 (permalink)
Re: New 6.0 owner
For, every negative story there is a positive one this truck is no different than any other I don't know of any truck that is perfect. I would keep the oil and filters clean and enjoy! If you happen to have a problem you will know it.
Late 2004, F250 SD Lariat FX4 Off-Road,CC, 8'box.
Banks six gun with guages, Banks intake, Banks SS 4x6". 285x75x16 REVOs on stock rims.
meangreen02 is offline
Old 12-01-2007, 12:48 AM   #3 (permalink)
Re: New 6.0 owner
Thanks, I have had my 96 7.3 since it was new and definitely knew when it had probs. Similar to recent posts, my 96 F250 stalled while driving on the freeway. Took it to a dealer, then took it in the shorts. Dealer mech was clueless.
96 F250 7.3
Old 12-01-2007, 08:22 AM   #4 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Re: New 6.0 owner
Get the dealership to run an OASIS report for you. This will tell you past repair history.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 12-01-2007, 10:05 AM   #5 (permalink)
Re: New 6.0 owner
By '04 a great many of the 6.0 problems were already "fixed". They changed the troublesome fuel injectors (C-94s) and changed the computer and several modules programming and even their locations. Most of the early problems were not mechanical.
My early '03 hasn't had any of the problems that sound so extensive and serious on this forum.
Enjoy your rig. As a previous writer said, do the maintenance, and if you are nervous about your new acquisition, go to a Ford dealer and ask for an "Oasis report". Put your mind at ease. Don't be afraid to get the latest computer "flash" updates.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
montanafan is offline
