New fuel filter, working pump but truck wont start - Diesel Forum - TheDieselStop.com
Old 12-19-2009, 10:29 PM   #1 (permalink)
Our 2007 f350 6.0 ran really rough this morning so we took a look at the fuel filters and they looked pretty bad. We replaced them and follow the directions provided with the filters and some from online. The truck started and ran for less than a minute, then it died and wont start again. I checked the secondary fuel filter/ bowl and the pump was sending a mix of fuel and air which would show that there is still air in the lines. Do we need to fill the primary filter with diesel? any ideas?
centralmasslandscapes is offline
Old 12-20-2009, 12:22 AM   #2 (permalink)
redneck_rheino's Avatar
My Photos: (36)
I've never had to refill the bowl when changing. check your main filter down on the frame to make sure you tightened the cap and its not sucking air.
*SOLD* 2005 F-350 XLT Supercab SWB PSD, Zoodad mod, Installed factory clearance lights and tailgate running light, line-x bed liner, sirius radio, GOS racing headlamp harness, Coolant Filter, Toyo M/T's 285 75r 18, platnum injection diesel catalyst system, 4 in straight exhaust, Blue FPR spring and 6.4 banjo bolts upgrade, delo 5w40 syn with hss, 2 stroke oil in the tank
Truck Pics
*SOLD* 2006 Ford Fusion SEL 3.0 V6 dark blue pearl
2011 Ford F-150 Supercrew XLT 4X4 6.5ft bed 3.5L ECOBOOST
2006 Chrysler Pacifica Touring AWD 3.5L V-6
redneck_rheino is offline
Old 12-20-2009, 10:01 AM   #3 (permalink)
69cj's Avatar
You could also have a damaged O ring on the primary filter. Did you coat it with oil and torque to spec? Did the cap bottom out. The O ring does the sealing not the threads.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 12-20-2009, 01:06 PM   #4 (permalink)
I had the very same problem the first time I changed the fuel filters on my 6.0 too, ran fine for about 1 minute, then died and would not start. Called my diesel mechanic and he said that was very common after a fuel filter change...air in fuel lines. My question to him was "Why isn't that even mentioned in the instructions on changing the filter!?" I was ready to have him come tow my truck back to his shop! He said the fix is rather simple: 1. Make sure the cap on the primary filter is tight and the o ring is doing its job of sealing...oil it AND the threads on the cap lightly. 2. Then, very slowly loosen the cap on the secondary fuel filter in the engine compartment until you hear the air in the lines rush out (I also had a small amount of fuel spew out, too). DO NOT take the secondary cap completely off...just loosen it to let the air out. Then tighten it again, cycle the key on and off a few times and it should start. Mine did run a little rough for a few minutes and then it smoothed itself out. Hope this helps...
2008 F-350 6.4L PSD, XLT, CrewCab, DRW, Long Bed, Torqueshift Auto, Fumoto Valve, Bilsteins
donniejimmy is offline
Old 12-21-2009, 01:30 AM   #5 (permalink)
I'm going to look things over tomorrow, the truck sat out this snow storm since we couldn't get the problem fixed last night. The cap had some trouble going back into the primary filter threads because of pieces of sand etc falling into the threads. I cleaned these up and it went in alot easier. What oil should i use on the o-ring? does the oil on the o-ring really make that much of a difference? I think i may be able to hear air hissing around the filter area when the key is turned but im not sure.
Old 12-21-2009, 10:22 AM   #6 (permalink)
69cj's Avatar
Any type motor oil or even vaseline. The object is to keep the O ring from pinching or binding till the cap bottoms out.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 12-22-2009, 07:00 PM   #7 (permalink)
Hey guys,
Thanks for the advice, I went out today and pulled the filter back out and put Vaseline all over the threads and o-ring, then I turned the key to get the pump going and remembered to loosen the cap on the secondary filter. Fuel sprayed everywhere when I did that since i forgot to do that first, but atleast I knew everything was working again. The truck started right up after a quick battery charge and is running alot better with the new filters.
