New heads/gasket design in early 06? - Page 2 - Diesel Forum - TheDieselStop.com
Old 04-16-2006, 02:19 PM   #16 (permalink)
My Photos: (21)
Re: New heads/gasket design in early 06?
You want to look at your engine build date, which is on the yellow sticker on the PCM. It's a little hard to find an angle from which to read it, but it'll look like 250106 (1/25/2006). My truck was assembled on the 26th and my engine build date is the 25th. I don't know how far apart the engine build date and truck assembly date typically are.
-john
1999 F-350 6-Speed SRW CC LB 3.73
jas10 is offline
Old 04-16-2006, 05:32 PM   #17 (permalink)
Rub
Ok my truck build date is 1-15-06 but my motor build date shows 1-06-06. I guess this means that even though my truck was built after they made the motor changes and should have gotten the update they needed to use up inventory on the old design [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Rub is offline
Old 04-19-2006, 11:22 AM   #18 (permalink)
Rub
I was just emailed from my dealer that they checked on my truck build and said Yes it does indeed have the Communization Engine! I hope with this new updated engine I will not experiance any coolant puking and head gaskets to replace like our 04 did.
I have to say that I love our new F-350 and it pulls our when loaded 19k 5th wheel like its not there.
Rub is offline
Old 04-20-2006, 12:13 PM   #19 (permalink)
Send a message via ICQ to agdodge4x4
Engine Commonization....nice.
AKA "Project Guinea Pig"
Jason
Texas A&M University
Class of 2002
2005 F-250 4x4 (FX4), Lariat Arizona Beige/Black two-tone, 5 spd Auto, 6.0L.
agdodge4x4 is offline
Old 04-20-2006, 01:24 PM   #20 (permalink)
Great info, could you direct me to the original source? Here or PM is fine.
Thanks...
'05 F350 CC LB SRW 4X4 auto
dosdedojack is offline
Old 05-04-2006, 08:15 AM   #21 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I noticed on my '06 the turbo inlet hose is different then the '04 year trucks.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 05-20-2006, 02:24 PM   #22 (permalink)
ROTFLMAO!!!
So, are these the same heads that will be used on the 6.4?
This space intentionally left blank.
444turbodiesel is offline
Old 05-21-2006, 02:49 AM   #23 (permalink)
My Photos: (6)
This info should answer your questions....The original document(pdf) contained part diagrams that pointed out the changes, otherwise it's as published...
Soooooo....how's all this improve performance, or is this early retooling?
Shucks, I'd be happy if they'd fix the EGR system. It's a recurring pain-in-the-kiester for just about everyone not running 90% highway miles.
Several hundred hwy miles sure clears mine out. Wish I did that more.
'04 Lariat 4X4 CC
CalWaterboy is offline
Old 05-21-2006, 08:03 AM   #24 (permalink)
Supporting Member
andrewbalser's Avatar
Ryan, the month/year build that you're referring to is on your door jam, right? This is when the truck was built at the truck facility. The engine build date that these other guys are referring to is(or used to be) on a 5x5 type label on what I believe is the fuel injector control model, which is mounted on the driver side of the engine, but near the back, kinda above the valve cover. Mine is visible by standing at the fender on the driver side, and peering down at the engine, by looking under the coolant degas bottle.
[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Keep on truckin
andrewbalser is offline
Old 05-23-2006, 12:38 AM   #25 (permalink)
My yellow sticker says 240306
'06 FORD F-250 FX4 CREW Dark Shadow Gray <font color="#FFFUUUU">
6.0L Power Stroke Diesel</font> w/ TorqShift
2.5" Daystar Level Kit & 4" Tuff Country Rear Blocks
7" In-dash Jensen DVD Player w/ Polk Audio Surround Sound
[b]<ul type="square">[*]1996 F-350 Singlecab 4x4 7.3L Diesel (SOLD)[*]2003 F-350 Supercab FX4 6.0L Diesel (SOLD)[*]2004 F-250 Supercab FX4 6.0L Diesel (SOLD)[*]2004 F-150 Supercab Lariat 5.4L 3V White (SOLD)[*]2004 F-150 Supercab Lariat 5.4L 3V Black (SOLD)[*]2004 F-150 SUPERCREW Lariat 5.4L 3V Black (SOLD)[/list]
jsoltis is offline
Old 06-01-2006, 09:40 PM   #26 (permalink)
My Photos: (21)
I have 5000 miles on my 06 now and there's zero oil oozing from the IC boots, zero oil splattered on the hood like my 05 had, and zero dried coolant around my degas bottle. I don't remember how many miles I had on my 05 before I had all 3 of the above, but it couldn't have been much beyond 5k if even that many.
What are you other 06 owners seeing? Especially those of you with engines built after the commonization switchover (1/11/06).
-john
jas10 is offline
