new location for temp sender
I had a coolant temp gauge installed , but the only place they could find to mount the sensor was low down on the drivers side of the block, and with the number of fittings they needed to get it to fit the gauge wasn't the most accurate, it lags behind the temp off the Dashhawk by a fair amount sometimes.
I ordered a coolant filter from the Dieselsite, and in their directions they mention using the extra inlet for a temp sensor. I'll try that when I install the filter and see if it's more accurate.
Thanks Dieselsite
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
