New owner of a '03 F-250 - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 11-01-2012, 07:27 PM Thread Starter
Hello guys, this is my first post. I have been reading for a few days and decided to sign up as I have a few questions.
I have seen that a few of the things I should do right away to know where I am at and hopefully adding some reliability is....
1. Change the coolant and add a coolant filter, I have seen that sinister is a common brand for this, is the quality of the kit ok?
2. Upgrade the oil cooler... I have seen a few kits around that look like they are an upgraded replacement for the stock unit. Is it not better to have an external oil cooler up front? Or should I stick with an upgraded OEM location unit?
3. EGR cooler upgrade..... Sinister unit quality ok?
All I can think of right now but I am sure I will think of some more.
2003 F-250
Diesel
255K Kms
FICM replaced
High pressure pump repplaced
Edge Programmer set to stock
That's all i know, I just bought it oct.5/12
Meat man is offline
post #2 of 11 (permalink) Old 11-01-2012, 08:15 PM
dcovaleski's Avatar
Congrats on your new truck!! Do a lot of reading here..you will learn a lot. To answer a few question (and this is only my personal opinion)
1. Not just change, flush the cooling system completely. Most of the systems are the same, just a bypass system with a cartridge filter. Refill with an ELC coolant with an ec-1 rating. Gold coolant is acceptable of you want to babysit it.
2. There are no known "upgrades" to the internal oil cooler. The BDP kit is nice, just a little excessive for the average truck owner. Keep clean coolant, and the factory oil cooler will perform just fine.
3. There is no need to upgrade the 03/ early 04 cooler....they are robust enough to the point that the oil cooler will usually fail before that cooler. Of course, if dont want the egr system
In there, simply delete it. Plenty of good quality aftermarket options available.
Again these are only opinions based on things that have worked for me.
2005 F-350 cc, 6sp, 4" turbo back MBRP, 03 turbo, ARP studs, Sinister EGR delete, Southbend clutch, SCT with custom tunes and really bald tires
1996 F-350 Reg cab psd auto 187k so far so good
dcovaleski is offline
post #3 of 11 (permalink) Old 11-01-2012, 10:43 PM Thread Starter
Thanks for the reply, I read that the egr delete would throw a code. I would like to delete it however I don't want a code nagging me every time I drive it.
2003 F-250
Diesel
255K Kms
FICM replaced
Meat man is offline
post #4 of 11 (permalink) Old 11-02-2012, 10:34 AM
Paul H's Avatar
My Photos: (10)
Unplugging the EGR will throw a code on an 05 and newer, but on an 03 to 04 it will set a soft code saying it is out of range. This will also effect the fan clutch operation.
My 04 is an early build with an 03 engine I did the delete but left the EGR valve in place and plugged in. No issues due to no EGR cooler and no way to suck exhaust in through an open egr valve and the fan works fine. Mine would puke coolant before the delete but without no issue.
Paul H
OWNER
2004 Ford F350 6.0L Dualie 273.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 343,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
Paul H is offline
post #5 of 11 (permalink) Old 11-04-2012, 10:38 PM Thread Starter
So hauling my horse trailer with 2 horses in it I am around 6000 lbs of trailer weight.
The oil temp got up to 229 F.
Isn't the max normal temp supposed to be no higher than 230F?
I wonder If a hot coolant flush would help the oil cooler any?
2003 F-250
Diesel
255K Kms
FICM replaced
Meat man is offline
post #6 of 11 (permalink) Old 11-10-2012, 10:58 PM Thread Starter
So I bought a oem service manual for working on the truck. And I came across the fact that there is an oil screen for the oil cooler. Is it worth removing the oil cooler and cleaning the screen and cooler itself in an attempt to lower the oil temps?
2003 F-250
Diesel
255K Kms
FICM replaced
Meat man is offline
post #7 of 11 (permalink) Old 11-11-2012, 09:39 AM
Does your Edge device have a gauge option and do you use it? The readings you see regarding ECT and EOT will tell you part of what you should know about the health of some of the engine components.
Doing a lot of reading on hear is going to be valuable as there are great many people who have either gone tthrough most of the problems or can give you some grear advice. Good luck.
baddna is offline
post #8 of 11 (permalink) Old 11-11-2012, 11:45 PM Thread Starter
Actually I was doing some reading last night on here and read it was actually more important (to a point) about the the delta readings. The edge does have gauges on it. Highest reading were 224 eot and 210 ect and for the majority of the trip was only a 10 degree difference.
Seems like there may not be as big of an issue as I thought there was.
2003 F-250
Diesel
255K Kms
FICM replaced
Meat man is offline
post #9 of 11 (permalink) Old 11-12-2012, 09:57 AM
The Sinister coolant filter is what I run. The kit is very well thought out and high quality. I highly recommend it.
As stated, flush the system and swap to ELC coolant. The factory gold Ford junk can't take the heat of a Diesel and is badly formulated for Diesel use.
You have the good EGR cooler. If you want to delete it you really should get an aftermarket tune to allow normal operation and no codes. Your year you will likely not get a CEL if the EGR valve is still plugged in, but the soft code can cause other issues as noted.
I would stick with the factory oil cooler system. If you are doing an EGR delete anyway I would advise this: do a coolant flush prior to any work, delete the EGR cooler and install a new oil cooler, install coolant filter, and fill system with ELC coolant. This addresses all the possible issues as once. The screen you note is for the HPOP and sits under the oil cooler. The oil cooler kit from Ford will have a new screen. Suction the reservoir dry, clean everything, and install the new screen.
Oil temp should never get to 240 or above. If it does change the oil immediately. Oil begins to break down at that temperature, and you lose lubricity which can kill the engine.
Ford specs a delta of not more than 15 degrees ECT vs. EOT. if you see more than that the oil cooler is shot. On a brand new oil cooler I see a delta around 2-7 degrees most of the time.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
post #10 of 11 (permalink) Old 11-13-2012, 11:06 AM Thread Starter
Thank-you.... that awnsered alot of my questions....
Isn't the oil cooler just a heat exchanger? Why cant it just be removed, sonically cleaned and re-installed? If its just build-up internally that should take care of it. Mind you I have not inquired on the pricing of a new oil cooler but im sure its more than a cleaning.
2003 F-250
Diesel
255K Kms
FICM replaced
Meat man is offline
post #11 of 11 (permalink) Old 11-13-2012, 04:34 PM
The oil cooler kit from Tousley is $269.43. Many people have tried to clean them, or to get them to show failure instead of just replacing them when they are suspect. It's impossible to duplicate the dynamic conditions the cooler experiences on a bench. The best bet is just to replace it, especially if the intake is already off for other work.
