New Tranny Fluid TSB - Diesel Forum - TheDieselStop.com
Old 08-25-2006, 01:38 AM   #1 (permalink)
beachbumcook's Avatar
Here is latest TSB on tranny fluid from Ford.
Torqushift transmission remains unchanged - still use Mercon SP (only)
Mercon V Use in Mercon Transmissions:
Effective 6-29-4, Ford is discontinuing Mercon ATF licensing and manufacturing. Mercon V is now approved for use in all transmissions specifying Mercon. This includes both the E4OD and 4R100 automatics (but not the 5R110 TorqShift), and the ZF six-speed manual, as well as the transfer cases. Once exsisting stocks of Mercon is depleted it will no longer be available. Transmissions that specify Mercon V should still use only that fluid. The ZF five-speed will still use synthetic Mercon, and the TorqShift still uses Mercon SP. TSB 06-14-4
03 Excursion 6.0L PSD - 4X4 Limited
Pioneer Airware XM2GO Statelite Radio
Racor By-Pass Oil Filter
Magnefine P/S Fluid Filter
Dieselsite Coolant Filter
Fumoto Oil Drain Valve/Plug
Marinco AC Block Heater Plug Mod.
Bilstein Shocks
Rancho Steering Stabilizer
Brite Box Headlight Module
24" Wiper Blades
beachbumcook is offline
Old 08-25-2006, 10:10 AM   #2 (permalink)
Re: New Tranny Fluid TSB
Now that THEY do not have to fix them under warranty, it is OK to use a fluid that the dipstick and owners Manual say not to....
HMMMM....
07HEMI4ME
Purchased a 2007 Dodge, ThunderRoad Edition, QC, 4x4, 5.7L HEMI on 11/30/07.
Traded in my Travel Trailer for it, so no need for a Diesel.
2003 EB Expedition 5.4L
2006 F350 Lariat, 6.0L PSD, Crew Cab, FX4, 4x4 PURCHASED BACK BY FORD! on 8/28/07.
07HEMI4ME is offline
