No boost - Diesel Forum - TheDieselStop.com
Old 05-29-2008, 12:20 AM   #1 (permalink)
No boost
Hi all. New "rookie" to forum.
My truck: 2004 F250 XLT, ext. cab, 2wd., 6.0, auto.
I tow: 32ft 5er. 12000lb loaded.
Any body have a clue???
While towing last week, heard a "pop". Lost all boost & power. Had trailer towed. Today, installed new intercooler boots on passenger side. No change.
Any help??
Buddy
Diesel Dad55 is offline
Old 05-29-2008, 03:37 AM   #2 (permalink)
Any DTC's? What boost numbers are you seeing? Any other symptoms (white exhaust, noise, etc)?
Mark
bismic is offline
Old 05-29-2008, 02:17 PM   #3 (permalink)
When I was towing and towing hard had the pop, more of a boom for me, and I blew the black hose that goes under the battery on the drivers side. It blew a quarter size hole right in the corregated part of the hose. Service manager at Ford garage told me that the black plastic should be replaced with the sluminum ones for just that reason. I lost all power and boost, not to mention the loud noise very similar to the old carberator cars with the air cleaner off. I could not see the hole, but could hear it and when I stuck my hand under the battery, I could feel the hole.
Good luck,
Bondo©
NEW 05 F550 4X4 Born 03/05, CC DRW pickup, kelderman air, 4.88 LSD, all stock for now!
Pics of new truck ; http://community.webshots.com/user/dave1958007
Tow 38' 3 horse LQ Sundowner. AERC member.
Old, SOLD 99 F350 4X4 DRW XCab, XLE4, 4.10LS, man hubs, auto, K/N air, 2 pod A-pillar, tranny temp/pyro, DynoMAX CAT back, WD Turbo Chip, TC lock switch, blue/silver, Reese goose.
Went to a good home in MO !!
1965 Galaxie 500, 4 dr, Thunderbird 352 4V SPCL 8 (fresh rebuild, purchased 9-28-65 for $2858.75 (still have original receipt and window sticker.
64 Ford pickup second owner, new project!
drbond is offline
Old 05-31-2008, 12:11 AM   #4 (permalink)
No Boost
No boost readings, no DTC's, no smoke, white or black.
Old 05-31-2008, 01:38 AM   #5 (permalink)
Banned
I'm going to be nice and warn you up front that getting a reply from me isn't always a pretty thing..
You have no boost and, from your description, you have a hole in what sounds to be a CAC tube....
Fix that first and then re-assess the concern. You have a nice "handle"... Please don't let me be an acidy old curmudgeon.
GrampyJim is offline
Old 06-01-2008, 10:55 PM   #6 (permalink)
No Boost
Update:
Pulled air filter & box. Checked all innercooler boots & pipes. Put superchips performance program in, just to see what would happen. Hp much higher, but no boost. CEL came on. DTC codes: P00603, P1000, P2623. Lots of smoke under this tune up. No smoke under stock tune up.
Old 06-02-2008, 12:43 AM   #7 (permalink)
dieselmankane's Avatar
Sounds like a possible injector failure (P0263 Cylinder 1 contribution/balance fault). When I lost the #4 injector the engine was producing little boost, but still boost. When you say "no boost" do you mean it in the literal term, as in "no boost", or is there still a liittle boost?
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
Old 06-02-2008, 01:08 AM   #8 (permalink)
Banned
P2623 is a concern with the IPR circuit... an electrical concern so at least we don't have to mess with datalogger and gauge readings... The IPR (injection control pressure regulator) is duty cycled by the PCM. One side of the two wire connector should have B+ on it and should be load tested rather than using a voltmeter as the pinpoint test is likely to suggest. You can use an ohmeter to test continuity through the IPR itself (should be between 3 and 15 ohms) but a better test would be to feed it B+ and a known good ground and feel/listen for the click. In my humble experience, it is rare for these to fail electrically. Key on engine off, IPR duty cycle will migrate to about 14% (warning - memory thing happening) making it necessary to load test the control side of the circuit by disconnecting the PCM connector. Notice I have, once again, mentioned "load testing" the circuit. The PC/ED manual is chock full of inappropriate test procedures.
Old 06-02-2008, 05:31 AM   #9 (permalink)
Great post GrampyJim - thanks.
If it is the IPR:
Later 04 (and up) ICP sensor change - passenger side valve cover (production beginning 9/03 placed the ICP here).
http://www.ford-trucks.com/forums/729593-icp-sensor.html
http://www.forddoctorsdts.com/articles/article-05-17.php
Injection Control Pressure (ICP) Sensor https://www.motorcraftservice.com/pu...1527/adobe.gif
Printable View (240 KB)
Removal: All vehicles
1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-01.
Vehicles with automatic transmission
1. Remove the transmission fluid level indicator.
2. Remove the retaining nut and disconnect the transmission fluid fill tube from the stub tube and
position it aside.
https://www.motorcraftservice.com/pu...9/A0065712.gif
All vehicles
1. Raise the vehicle.
2. Remove the bolts and the turbocharger heat shield.
https://www.motorcraftservice.com/pu...3/A0065771.gif
4. NOTE: It will be necessary to position the heat wrap aside. Disconnect the injection control pressure (ICP) sensor electrical connector.
5. https://www.motorcraftservice.com/pu...2/A0077287.gif
6. NOTE: Use a 1-1/16 inch 12 pt. deep flare nut crowfoot wrench, such as a Snap-On® AN850817B, GAN850817B or equivalent, to remove the sensor. Remove the ICP sensor.
7. https://www.motorcraftservice.com/pu...9/A0079758.gif
Installation:All vehicles
1. NOTE: Verify the ICP sensor has the O-ring in place. Install the ICP sensor.
https://www.motorcraftservice.com/pu...0/A0077288.gif
2. Connect the ICP electrical connector. Position the heat wrap back over the electrical connector.
3. NOTE: Engine removed for clarity. Install the turbocharger heat shield and bolts.
https://www.motorcraftservice.com/pu...4/A0065669.gif
1. Partially lower the vehicle. Working from outside the right wheel area, engage the transmission fluid fill tube to the stub tube.
2. Lower the hoist.
3. Install the fluid fill tube retainer nut.
https://www.motorcraftservice.com/pu...2/A0065741.gif
4. Install the transmission fluid level indicator.
Mark
bismic is offline
Old 06-02-2008, 09:46 AM   #10 (permalink)
My bad I read his code wrong. Don't listen to me.
[SIGPIC][/SIGPIC]
Old 06-02-2008, 09:19 PM   #11 (permalink)
I truly appreciate all the advise. Ive learned alot!!! But,..... guess Ill bite the bullet and take in to dealer for service. Hope I have no issues with the warrenty, (as far as the exhaust and intake).
Again, many thanks,
Buddy
