No Heat - Page 2 - Diesel Forum - TheDieselStop.com
Old 01-26-2013, 10:05 AM   #16 (permalink)
IIRC a friend of mine bought an "03" used and someone had removed the vac solenoid from the inline hose for the heater. long story short, I finally found the long grey vac hose that went to the solenoid and connected it to a stub on the heater/ac box the one that has the blower attached. there is a nipple on the upper right hand side of the box. I plugged the vac stub into that nipple. HEAT. That was 8 years ago, he is still driving it. Hope this helps.
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 70,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/170,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline   Reply With Quote
Old 01-26-2013, 10:25 AM   #17 (permalink)
Jetboy - You are saying that the thermostat is different for an 03 and early 04 engine vs a mid 04 and later one? If so do you have part numbers?
My info says they are all the same: 3C3Z-8575-AA
boonedawg - any updates?
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD Billet WaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
bismic is offline   Reply With Quote
Old 01-26-2013, 12:09 PM   #18 (permalink)
dcovaleski's Avatar
No Heat
03-07 all have the same thermostat.
Sent from my iPhone using AutoGuide.com App
2005 F-350 cc, 6sp, 4" turbo back MBRP, 03 turbo, ARP studs, Sinister EGR delete, Southbend clutch, SCT with custom tunes and really bald tires
1996 F-350 Reg cab psd auto 187k so far so good
dcovaleski is offline   Reply With Quote
Old 01-27-2013, 11:26 AM   #19 (permalink)
Thanks!
Just getting back to y'all. Freezing rain since yesterday, had to use the cold, cold truck to rescue a couple of friends! Bismic - Just telling you what the parts store gave me first before I pulled the old one and took it in for proper thermostat..lol. 03PS, gonna have a look per your suggestion and will report back. Want to be sure to thank all 3 of you for jumping in. First time user, y'all literally saved me from lighting the truck on fire, felt so alone w/all these issues!!!! Still pissed. Love the truck, hate the engine. Dropped over $4 G's since buying a year ago and now that it's averaging 10 - 20 degrees outside it's cold in that dang cab!
jetboy44 is offline   Reply With Quote
Old 01-27-2013, 12:01 PM   #20 (permalink)
OT
OT's Avatar
J...My job 1 03 has only one grey vac. line going to box (like 03 saying) but also nothing in heater hoses like you found out. When you turn on heat, do you hear a "thump" kinda sound inside cab? Appears your 04 has 03 6L. Hope you get it fixed, know you do.
btw..I use little 12V heater/fan that helps on cold/icy mornings here, until I get cab heat.
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
Old 01-28-2013, 11:51 AM   #21 (permalink)
How cold is it outside? Try covering the radiator with cardboard to get the temp up. The thermostats fail open so this could be the problem. The engine temps should be 190+. Mine is 170 to 180 and I have the replacement thermometer ready to go when I get a weather window to replace it in.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty.
Ford06 is offline   Reply With Quote
