Anybody have this problem, It's an 04 6.0 when I accelerate it will blow hot air and when at idle it blows cold? any way it's going to the dealer in the morning
Ross
Last one I had like that needed a heater core to fix it. A late 03 with only 32,000kms on it and seemingly good flow through the old one using a garden hose, I was nothing less than surprised. Something we forget.... head pressure in a towns water system is much higher than that produced by the water pump on our engines.
Here are the symptoms I encountered.... good heat while at speed..... heater output cooled fairly quickly at idle.... 30 seconds or so would put heater output close to outside temp (between freezing and 0F at the time I was diagnosing).... temperature gauge in the cluster did not change when the heater cooled or warmed..... ECT reading on the WDS did not change when the heater warmed or cooled. Hotline turned into lukewarm line on this concern and had me chasing unicorns....
I have the extact same issue.. I just discovered it this morning.. NO IDEA..
2003 f250 SD Arizona beige
engine build date is 12-23-02 and a Jan 03 truck.. sct tunes,daily driver.
2 bad injectors, blown headgasket,bad egr, bad ebpr,front brakes,ohh and a bent pushrod.
yeasu ft90... 305 70 16 nittos..
4 inch stainless all the way..
afe intake...
3 dogs
1 glock
107k as of 5-18-06
116k as of 7-9-06
118k as of 8-17-06
125k as of 6-27-07
When that happened to my truck my dealer asked if the overflow was at the min level and it wasnt so they told me to fill it, watch it and see, 1 year later and 1 more fill this fall and I have had steady heat but never the heat that For% trucks always produce.(nice and toasty with minimal fan!)
2008 F350 King Ranch
2007 Ford Edge
1999 Club Car golf cart 6"lift 23" tires
2008 Firefighter ultra-classic Harley 105"
got the truck back form the dealer. It tured out to be a bad radiator hose. the reason I never noticed is that I have a gravel driveway [img]/ubbthreads/images/graemlins/shrug.gif[/img] The anti freeze was not full enough to go threw the heater core. they replaced the hose and topped it of.
I'm having a heater problems. I drive down the road and the heat will just go from hot then cool to cold and then then back to hot again. It does it at very randon times. Sometimes going up hill, sometimes going down hill, at one stop light but not at others, and so forth. Just driving down the road the engine temp stays right in the normal range with no flucuation.
What I've tried. Flush the heater core and every line that i can find. removed the heater control valve that is located by the oil filler neck, added a second layer of cardboard to the front of the radiatior. Changed the thermostat.
I am now out of ideas. Any new things to try would be helpful.
'04 F250 Harley Crew Cab, 4x4, black over grey,
Black Widow Diesel 6.0 Twin Turbos
Hypermax custom injectors, rods and alot more.
TURBONETICS Turbos
SCT Custom Tuning by Innovative Diesel.
Assuming your coolant level's good and you're not adding coolant, there is an on/off valve in the coolant line to the heater. If that's the heater control valve you changed, I'd look for an electrical problem. You'll notice on Max AC that there's no heat....that's the valve operating.
Hey, anyone know if it's normally open? Normally closed?
I'd like to have heat in Max AC....it's nothing more than recirc mode. If that can be fixed by the wire falling off, great.
The Japanese do it better - Ford's recirc control is awkward; crude. So's their cruise control. Check Honda & Toyota.
Head gasket? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
my coolant level is full. I have been filling it. Now that it is cold I fill it at about 1 gallon per month. Mine is a puker. I'm scared a head gasket is the problem. Would bad head gaskets cause this, maybe air pockets. I now that when head gaskets cause low coolant then no heat is an issue. My coolant isn't low???
I pulled the coolant return line off at the overflow bottle, from the egr cooler and I get a lot of air bubbles, maybe exhaust gases in this line. Maybe holes in the egr cooler causing puking and no heat?????
Try keeping coolant @ minimum level - may puke no more. Isn't there a chemical check for exhaust in coolant?
I would like to start by saying last year I was in -20 degree temps and did not need to cover my radiator to get heat out of my truck and it didn't have this problem.
A heating system is very simple right? The water pump pumps coolant throught the heater core, a fan blow heat out of the vents, the coolant retuns to the overflow bottle. This will happen even if the thermostat is in any position.
Is there only one valve that control the coolant flow to the heater core, the one by the oil filler neck? I removed this possible restriction.
There are also flaps inside the heater box to control if the air flow into the truck through heater core or not??? If I turn the heater control know I can hear a sound difference in the air flow sound. It does this even when the heater is blowing cold air.
As long as the coolant is full enough shouldn't the water pump pump even if the head gaskets are bad??
Are there more valves on the truck other than the one I removed that control coolant flow through heater core?
TURBONETICS Turbos
A bad head gasket can cause intermittent heat loss by causing an airpocket that works it's way through the cooling system. Being a puker makes it sound all the more likely that it could be a bad head gasket causing the problem.
