No power going up hill - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-22-2010, 11:26 AM Thread Starter
I have a 2003 6.0 with 85,000 miles on it 6 speed transmissioion. In November while pulling a 35" trailer I lost all power I pulled off to oth side of the road and replaced the upper fuel filter. This filter was completly plugged and when it was replaced this fixed my issues. I drove this another 100 miles before replacing the upper and lower filters as part of a matched set.
Now the issue I am having is the truck now feels like it is missing when going up even a slight grade. Slight vibration and no pickup power. The second place the problem is noticed is passing a car same no passing power. But the truck runs fine going down hill ior on the flat.
I'm guessing I messed up a fuel injector. Is this a proper assumtion or did I screw something else up. There is no check engine light and I still have original batterries.
Is there anyway to check the injectors or is this a dealer only Troubleshooting technique.
Any help or advice would be greatly appreciated.
2003 F350 CC 4WD 6.0L 6 speed 63235 miles
kyleandtara is offline
post #2 of 3 (permalink) Old 01-31-2010, 06:35 PM Thread Starter
Any one?
post #3 of 3 (permalink) Old 01-31-2010, 06:43 PM
That sounds more turbo related to me, but I'm no expert. ?
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X with pop-up bull ring tie downs, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank (holding a Powerstroke tool) + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock. 80+k miles, 1900+ hours.
ljr869 is offline
