not starting with the key...help!!! - Diesel Forum - TheDieselStop.com
Old 11-14-2009, 11:44 AM   #1 (permalink)
I've got a 06 350 6.0l it's mostly stock but the starter was sticking sometimes
all I had to do was tap it with a hammer and it would let go.... it hasn't stuck for a long time now but it won't start with the key.... how ever if I short it by the battery it starts fine and hardly ever sticks..... the key still runs the glow plugs and turns the power on but does nothing else..... has any one had this problem before?
2006 -350 XLT FX4 auto w/leather cc/sb. it's all white bumpers, trim, and everything else. 6inch lift with 325/65r18, High Idle mod, GlowShift FP gauge on corner post, banks six gun with PDA i only us for the guages, SCT X3 with custom tune from RCD. RCD engine oil bypass, 155 sticks, ITP regulated return with airdog, EGR Fixed forever, 6 PIAA Lights, black oynx gaskets with ARP studs. banks air box.
dieselmanwithatan is offline
Old 11-14-2009, 01:03 PM   #2 (permalink)
MikeL46's Avatar
My Photos: (14)
I'm not sure where or what you are shorting. I'm guessing you are not crawling under the van and shorting the batteries.
On my 04, there are the ignition switch, the powertrain control module, 2 fuses and the starter relay before the starter motor. F1.7 (60A) and F2.33 (10A) I'd guess one of fuses blew when you shorted the wrong thing. On an 06, the fuses may have different numbers, but probably not.
Take a voltmeter and measure the power at F1.7. If ok, go to F2.33 and check if power comes into it when the switch is in the START position, then see the voltage comes out of the fuse. Then you will have to verify the PCM is grounding the starter relay. Check the starter relay by swapping with another relay in the Battery Junction Box.
What exactly are you shorting? With a screwdriver or? That may give a clue as to what is working and what is not.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 11-15-2009, 12:59 PM   #3 (permalink)
There's a black wire beside the passangser side battery that has a round conector on it... I've been just taking it apart right there and touching it to the positive side the the battery. with the key on it'll start right away.
Old 11-15-2009, 02:58 PM   #4 (permalink)
MikeL46's Avatar
My Photos: (14)
Sorry, I'm always thinking van with the batteries under the body.
Probably the electricals are similar. Find an electrical schematic and follow the signal from the switch through fuses and starter relay.
Good luck,
Mike
MikeL46 is offline
