Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (http://www.thedieselstop.com/forums/)
-   6.0L Power Stroke Engine and Drivetrain (http://www.thedieselstop.com/forums/f23/)
-   -   o4 6.0 does not get up to operating temp (http://www.thedieselstop.com/forums/f23/o4-6-0-does-not-get-up-operating-temp-375578/)
69 cobra 09-16-2013 07:57 AM
My 04 6.0 will not reach 192 temp. even on hot days unless operated at high speeds or up mountain grades but cools back to around 168-178.My thermostat has been replaced . Any thoughts where I should start next.Thanks chris
dannyboy950 09-16-2013 09:10 AM
You may have gotten a bad thermostat was it a motorcraft or an aftermarket.
Ford/motorcraft are designed to fail open.
TKOPerformance 09-17-2013 07:53 PM
And it sounds like that's what's happened. Either that or you've got a bad sender. Are you sure those temps are real or just what you're seeing on the gauge?
2stroked out 10-01-2013 09:40 PM
Had the same problem. Changed to a new ford thermostat, then an aftermarket, and then another Ford . The last one brought the temps up. Also when the temps are low my deltas were greater. I had even done the flush, and was running with cardboard in front of radiator. So good luck, and get a Ford thermostat from a different dealer. So your maybe not getting one from the same lot. About drove me nuts trying to figure that one out.
Guess I need to update my sig to reflect the cure on low temps.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
