obd2 port - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-09-2011, 07:22 PM Thread Starter
obd2 port
so I recently purchased a 04 6.0 litre. Im having trouble connecting a scan tool to the port. checked the fuse and it is good. ciggarete lighter does not work either. I was tracing the wires to the port and one of the wires(white and blue stripe) is cut off. Is that normal? Im not great with wiring so any help would be great.
2004 Ford F-250 6.0l auto 4x4.
jshort12 is offline
post #2 of 7 (permalink) Old 10-09-2011, 08:53 PM
I couldn't find anything with a white/blue wire, but I recently blew the fuse that powers the OBD-II and cigar lighter and replaced the wrong fuse. After a lot of tracing, I discovered my error and all was well.
Check the fuses above and below the one you think is the correct one. It's easy to miss count when you are standing on your head and trying to see what is in the fuse block. It does look like there is a blank between the top 2 fuses, but there is not. My owners manual shows it is fuse 2-12, #3 in the second column of fuses.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
johnmart is offline
post #3 of 7 (permalink) Old 10-10-2011, 12:04 PM Thread Starter
I'll have a look today. I dont actually have an owners manual so im just going off info I find online. I really hope I am looking at the wrong fuse!
jshort12 is offline
post #4 of 7 (permalink) Old 10-10-2011, 12:41 PM
chuckster57's Avatar
Another thing with these little fuses is that they can look okay but be burnt at the ends, meaning the very top corners under the writing making it hard to tell. I use an OHM meter to verify good/bad.
What kind of scan tool are you trying to connect. The generic code reader from the A/P store will not really get you anything. I have an Innova 3140 and when my friend was thinking of purchasing a used PSD ('04 I think) he brought it over and I wasn't able to retrieve very much useful information. VERY LIMITED live data..I was trying to check EOT/ECT deltas.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #5 of 7 (permalink) Old 10-10-2011, 02:54 PM Thread Starter
So I was just looking at the wrong fuse. Can't trust all info you find online I guess.
I'm hooking up my android phone and it seems to work good. The real time info seemed accurate. Showed one code, for my transmission temp sensor.
Could this scanner pick up some codes but not others (like injector codes? ) or would it pick up everything or nothing at all?
jshort12 is offline
post #6 of 7 (permalink) Old 10-10-2011, 07:23 PM
dieselmac's Avatar
Not sure what kind of scan tool you are trying to connect. Whatever you use needs to be capable of reading Ford Enhanced PID's if you want to get to the good stuff.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #7 of 7 (permalink) Old 10-10-2011, 07:33 PM Thread Starter
It is the torque app for the android phone. Not sure if it can read those or not. Ill have to look into it.
jshort12 is offline
