if you remove the snorkel you will be sucking in hot air from the engine bay instead of cold air from out side, the stock intake on 6.0s is good engouh unless you have a pretty big turbo on it, plus most aftermarket filters dont filter near as well as the stock one does.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
Keep the factory setup. you won't see any benifit from a performance set up.
*SOLD* 2005 F-350 XLT Supercab SWB PSD, Zoodad mod, Installed factory clearance lights and tailgate running light, line-x bed liner, sirius radio, GOS racing headlamp harness, Coolant Filter, Toyo M/T's 285 75r 18, platnum injection diesel catalyst system, 4 in straight exhaust, Blue FPR spring and 6.4 banjo bolts upgrade, delo 5w40 syn with hss, 2 stroke oil in the tank Truck Pics
*SOLD* 2006 Ford Fusion SEL 3.0 V6 dark blue pearl
2011 Ford F-150 Supercrew XLT 4X4 6.5ft bed 3.5L ECOBOOST
2006 Chrysler Pacifica Touring AWD 3.5L V-6
Removing the snorkel is an excellent idea! I actually modded mine to still have a small shroud for the front of the filter element.
I have used my SCT to datalog the intake temps there is a short rise in intake temps only on takeoff. After 15MPH you will be pulling in ambient air temps. Doing the ZOODAD will increase the directed outside air flow to the front of the intake. The thought process that all you will do is suck under hood heated air is not accurate information.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
No bullsyit?? That's interesting. Where is the intake air temp sensor?
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto
I believe it may be part of the MAF, but I'd have to check. When I got my Live Link running on the truck you have a parameter selection menu. You select what things you want to monitor and log. IAT was one of them (inlet air temp). I selected that one plus a few others, when I started the truck and the logging the IAT was only a dgree or two off from my EATC. As I started driving IAT would increase slightly maybe +10* max, then would settle out as I reached 15MPH + to the same temp of EATC. When I stopped the IAT temp would start to rise after 2-3 mins standing still, then upon take off and reaching 15MPH+ would drop back down again to the same reading of the EATC.
Now I'm not saying this is gospel but I got the file saved somewhere of my log session. I have never seen any real proof to say all you pull in is underhood heated air with a modded intake (or snorkle removed) so I got the proof myself. I was kind of surprised with my results to say the least.
Heavy Assault :
Thanks for the info!! I am not nearly as up on this as you, but I may get a S&B High flow replacement element and adapt it to my filter housing. I think I could cut the epoxy around the filter element,remove it, test fit the new S&B and then cut away the rest of the outer casing that I don't need. If it works it sure beats 300.00.
Thats more money I can put into ARP's.........Rats!!
Dude DON'T believe the S&B hype. I have read that "report" and while it shows some apparently good numbers S&B doesn't hold a candle to the OEM filter. In fact the OEM filter will hold more particles flowing more air LONG after the S&B has clogged up. IF you want me to talk about (easier on the phone) PM me your number and I'll call.
Here's what I did to my intake.
Reason: Added pic link
that is interesting about the increased air intake but what about clean air? i just got my truck back from the shop (oil cooler EGR went away). the tech found pitting on my turbo intake housing and replaced it. is the stock filter going to keep the intake air cleaner than an aftermarket? just wondering if i should look into a different set up?
If you read the S&B intake report the proof of the ability of the OEM filter to trap more dirt is right in the report. Read through all the first and second page. Then pay attention to the page titled "ISO 5011 Air Filtration Standard". It clearly shows at the top that the OEM filter will trap more particles (in grams) then the S&B by as much as 86%. WHat the report fails to show is the amount of particles required to reach the "Net Restriction" amount.
If the pretty "Restriction vs. Airflow" chart reflected the amount of grams in particles the intake trapped at those key points the OEM would be WAY far ahead of the S&B.
Don't believe the hype about S&B, the best part is they give you the results and it shows the OEM is MUCH better for airflow even when trapping dirt gram for gram.
