oil aeration? - Diesel Forum - TheDieselStop.com
Old 03-22-2009, 09:48 AM   #1 (permalink)
Djanzen's Avatar
oil aeration?
What is the most common cause of oil aeration on the 6.0? my truck starts and runs like a champ when stone cold, but as soon as it warms up it runs like crap! stalls will not start until cold again. if you keep the rpms up to 1500 it will stay running sounds like crap. if you get it going down the road and rpms up 2000^ it has lots of power but as soon as it comes to idle it will stall. fuel pressure is 55 psi at idle filters have been changed. no codes in ecm, new icp sensor.
2003 F250 Larait Grey/Black 3.5" lift 33" tires Bully Dog Tridog with Outlook monitor MBRP 4" ex. KC sunshine out front
Djanzen is offline
Old 03-22-2009, 11:26 AM   #2 (permalink)
Usually overfilling it. putting 15 quarts in after an oil change will put it just a wee bit overfull on the dipstick. Another cause is fuel in oil. Usually overfull will result in romps.
If this were an 05, I'd suspect the STC fitting at the HPOP, but the 03 doesn't have that type of fitting. I'd say you have a leak someplace, or the ICP is failing.
OMC
OMCUSNR is offline
Old 03-22-2009, 02:14 PM   #3 (permalink)
wong type of oil is a big one. i doubt its your problem though like ocm said high pressure oil problem or fuel problem.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
