oil bypass filters - Diesel Forum - TheDieselStop.com
Old 08-03-2009, 09:55 AM   #1 (permalink)
oil bypass filters
For those who are running oil bypass filters, whose are you using? where did you locate it? and is anyone using both oil by-pass and coolant filters?
Doug
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
dougjpr is offline
Old 08-06-2009, 02:25 AM   #2 (permalink)
I have both an oil bypass and a coolant filter. Coolant filter is in the engine bay. I have an Amsoil bypass filter that uses two filters that is mounted on passanger side frame rail between front and back door. It comes off the stock oil filter cap and fills back into oil filler. Both caps are from Amsoil.
new2deisel is offline
