oil cooler - Diesel Forum - TheDieselStop.com
Old 01-06-2009, 10:57 PM   #1 (permalink)
Exclamation oil cooler
Hi, I just ordered a new oil cooler over ebay and need to replace the old one. I had white smoke on my 2005 F350 and took it to the Ford dealer, 3000 miles over warrenty. They told me I needed a oil cooler and a egr valve. I replaced egr with a bypass kit and am wondering. Where is the oil cooler, on front of radiator? I can't affoird to pay Ford to replace it can anyone give me a replacement procedure. I did the bypass hopefully it is not rocket science.... Please help.... thanks in advance
cgeddie is offline
Old 01-06-2009, 11:09 PM   #2 (permalink)
teamroper60's Avatar
The cooler itself is underneath the oil filter base.. All that stuff you took off to do the EGR cooler delete will need to come back off to change out the oil cooler....... From there, it should be pretty straightforward.......
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 01-06-2009, 11:23 PM   #3 (permalink)
please tell me no
cgeddie is offline
Old 01-07-2009, 12:16 AM   #4 (permalink)
Unfortunately he is correct. If you google "6.0l powerstroke bible" you can download that and it will show you where it is.
Unfortunately the link to the Ford Workshop manual that I had no longer works.
I'm no mechanic, but if your EGR cooler is no longer in place, I would suspect the head gaskets before the oil cooler. I'm not too sure how the oil cooler would cause white smoke out the exhaust.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
kc2kgt is offline
Old 01-07-2009, 12:38 PM   #5 (permalink)
OT
OT's Avatar
cg..look here 6.0L Bible Table of Contents Good luck!
kc..I also lost the workshop manual link.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 01-07-2009, 05:47 PM   #6 (permalink)
did they say why you need a oil cooler? probly doesnt even need one, wont cause white smoke, the egr cooler will but not the oil cooler.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
