Oil Cooler Failure - Diesel Forum - TheDieselStop.com
Old 10-29-2009, 02:43 PM   #1 (permalink)
Oil Cooler Failure
Well, I finally had my first major issue with my 04 F350 4x4 Crew. I have what looks like tan, thick paint in my degass bottle. Needless to say the oil cooler pooped the bed. Dealer is quoting approximately $1200, 95,000 total miles so under 100K miles but 5 months out of 5 year warranty. Does that sound about right. He is also stating a 2 to 3 day job. Sound about right?
Thanks.
PS. I contacted Ford Customer Service to see if they'd cut me a break on the repair since I'm so close to running out of warranty.
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
newtodieseling is offline
Old 10-29-2009, 03:04 PM   #2 (permalink)
pennery's Avatar
Good Luck with Ford Customer Service... I was 10,000 KMS under my 160K warranty and 1 month out and I couldn't get them to pay for squat when I had an injector fail... "There is nothing we can do" they kept saying... I don't really think I am an unreasonable person by asking that they at least pay part of the repair... Especially since they have been having issues with injectors in these trucks to begin with...
I don't know anyhting about the oil cooler so good luck with that...
2003 F350, 6.0L Lariat 267,000kms, Stock except for the Pioneer in dash Nav unit with Back-up Camera... STOLEN May 16th, 2011. Still looking for her replacement **** Got my truck back from the Insurance company.
pennery is offline
Old 10-29-2009, 03:29 PM   #3 (permalink)
Thanks.
I had about a week left on my 5 year/100K mile warranty when my egr/oil coolers went out, dealer also replaced egr valve and flushed the cooling system and changed oil all under warranty ($100 ded) they had it three days, he told me appox $2700 job, I have seen others stating on here approx $2300. Look into a coolant filter after its fixed, something we should have done along time ago, good luck with the truck and the warranty claim!!
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 10-29-2009, 03:46 PM   #4 (permalink)
Strokin' 6.0's Avatar
Make sure that they replace the EGR cooler too, otherwise you're going to have problems again, and it's going to cost you more money,,,,,,,again.
Some stealerships like to do that.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 10-29-2009, 05:16 PM   #5 (permalink)
this job is a pain. they gotta replace all the hoses, the oil cooler, most shops will replace the egr cooler and send the radiator out to be cleaned. then you gotta run simple green through the cooling system to clean as much out as you can. then they'll run fords cooling system flush through it a couple times. you quote sounds actually pretty good seeing as this is a big job. but you said your 5 months till you go out of warranty and this should be covered.
6.0 tech is offline
Old 10-29-2009, 05:58 PM   #6 (permalink)
Actually, I'm 5 months OUT of warranty. I could tell by the gunk in the degass bottle that it would take some time to clean this out of everything. They told me there is a kit, around 300 bucks that would permanently fix this issue whereas in the past they were fixing it and it would happen again. Considering how much I tow with this truck, and I'm ashamed to admit I was hauling 30,000lbs gross weight (truck, grain cart and oats) and regularly tow 14,000 lbs I can't complain about the truck. Sounds like I'm getting a fair price and that's all I can ask for.
Bone Stock
Old 10-30-2009, 07:26 AM   #7 (permalink)
FTG-05's Avatar
My Photos: (25)
Assuming it's just the EGR cooler, they should replace the EGR cooler, oil cooler and degas bottle. Cost = $2200 here in north Alabama at the local dealer. About a 2 day job.
Second the comment to adding a coolant filter. In all likelihood, this would have prevented the EGR cooler failure in the first place, or at least mitigated it greatly.
Good luck.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 10-31-2009, 12:31 PM   #8 (permalink)
I have never heard of other engines having these problems. Why does the 6.0 have so much casting sand left in it?
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 10-31-2009, 01:33 PM   #9 (permalink)
FTG-05's Avatar
My Photos: (25)
I don't think the 6.0 has any more casting sand than any other engine, I've seen pretty much the same stuff in about the same amount in the first coolant filters for the 7.3 PSD and the 5.9 Dodge gasser motors.
What's different about the 6.0 is it's asymmetric liquid-to-liquid oil cooler, with engine coolant on one side and engine oil on the other side. Guess which side has the smaller passages? Yep, you guessed it, the coolant side.
The oil cooler coolant side is in series and comes before the EGR cooler in coolant flow. Therefore, when the oil cooler coolant passages plug up, it reduces and finally stops coolant flow to the EGR cooler. After enough running time and especially when towing or under heavy load, the EGR cooler fails, sending exhaust gases into the coolant system, end result: "puking" out the degas bottle.
These symptoms look just like failed head gaskets, hence early 6.0 failures were oftentimes misdiagnosed as head gasket failures; this is not to say that the 6.0 doesn't have head problems, it does and the number and size and use of head bolts instead of studs is the culprit.
Hope this helps.
Al
FTG-05 is offline
Old 10-31-2009, 02:39 PM   #10 (permalink)
Hope this helps.
Al
Yeah, I knew that Al, but it's always good to get a refresher. It would seem that relocating the oil to an external location would be a good idea. I see that there are a couple of companies that make the external oil coolers, but I have yet to talk to someone who has actually put the product on their truck.
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 11-01-2009, 02:17 PM   #11 (permalink)
teamroper60's Avatar
I agree with Al. It isn't the amount of casting sand. The problem is the design. Whoever thought to put an oil cooler with too small of passages that can easily clog, directly between the water pump and the EGR cooler, should be forced to repair everyone of them that breaks.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 11-01-2009, 02:56 PM   #12 (permalink)
Agreed.
Fred
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Old 11-10-2009, 04:50 PM   #13 (permalink)
Well, you boys were right. The Ford Superduty Team has decided not to "participate" in this repair. Total bill was $1822. Oh well, at least I have it back and knock on wood that will be the last major repair bill I'll have. I guess I need to stop pulling 29,000lbs gross when I'm using it on the farm before I fry something else. BTW, I don't recommend pulling that much total weight, truck, 550 bushel grain cart filled with oats, it pulls great, stopping, not so much
Bone Stock
Old 11-10-2009, 05:20 PM   #14 (permalink)
What oil cooler is this post about? Engine or auto transmission and where is it located? I see some sort of oil cooler below the Radiator in front. 2000 F250 SD 7.3 stick
F-250 2000 4x2 SC SD Long Bed, 6-speed, American Racing 'Kong Wheels, Glasstite Camper Shell & Vintage Airstream gone...! Replaced with vintage Pop-up Sunlight Truck camper that fits in garage.
klutz1 is offline
Old 11-10-2009, 08:33 PM   #15 (permalink)
The engine oil cooler. It is in the valley on the front of the motor below the oil filter.
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
