6.0L Power Stroke Engine and DrivetrainDiscussion of the 6.0L Power Stroke diesel engine and drivetrain in the 2003-Up Super-Duties and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
While at Wally World a few minutes ago, I decided to check out the 6.0 oil filters. The Fram's($15 and change) are now made here in the USA, but look like the one made in Germany except for the shrink wrap. They had one box that looked like it had been there for a while. The part # was put on with a sticker, and the box said "Made in Korea", but the filter inside was shrink wrapped and said "Made in Germany". I don't think anyone is shrink wrapping any more even the Motocraft is not shrink wrapped.
Yesterday I saw the Puralator filters are now 2-piece. The filter has the felt washers on both ends and the part that clips to the filter cap is separate so the filter goes in either way then the top fits into the filter. Later I was O'Reilley's and they had the same filter in their brand for $9.99. I don't see any problem in using these filters. They sure looked better that the new WIX.
I agree we shouldn't bargain hunt for filters, but we should be open to the possibility that some others are as good as OEM. I'm trying the Purolator PureOne filters now. I've used Purolators for years with great success, these seem to have very good filter media (regular purolator looks similar to OEM), and they are comparably priced to the Motorcraft filter found at Wal-mart.
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
amsoil makes the best 6.0 filter available, just visually comparing there isn't anything that comes close, 98.70% filter efficiency@15 micron per iso 4548-12.
good for 15/25k diesel application used with amsoil aka moose milk
1987 F250 dually 7.3 banks sidewinder C-6 GV overdrive 3.55 lots of factory eliminated mods
i/e rear hung single battery, re engineered fuel system, no more tank switch, electric holley blue pump, return style regulator, #8 fuel line feed and return, both tanks, Amsoil 5w30HDD with full flow / bypass filters, Amsoil of course.
Evans coolant and Amsoil conical air filter. last oil drain 2003 65k ago. I add about 8qt per year with filter change. rear main likes to leak parked only.
Here we go again, another post Amsoil-hijacked. Idiabuse, I appreciate that you've found a product you like, but maybe you can temper your posts with something different from time to time. Regarding filters, I won't doubt Amsoil has a good one, but there is no proof its the best. The one I'm using also claims 98%. The OEM one is very good I undestand as well. No full flow filter should go 15/25k miles, especially comparing the ease to change versus the risk.
Show the folks in the 6.0 forums something real - you start driving this motor, run Amsoil in it at 25k change intervals, and then when you have 200k on the engine, let us know.
Mark
Built: 11/03/03
I have purchased and used oem 6.0 oil filters and amsoil filters, seeing both oem/aftermarket then an amsoil filter anyone that has two good working eye balls and half a brain can tell wich filter has superior cababilities from ten feet away.
'05 Excursion 6.0L with Air Lifts and Bilsteins, high idle mod., only 'tuner' is in the radio, towing an '00 HR Alumascape 31SKS with a Hensley.
[/ QUOTE ]I used the amsoil filters as soon as they were released.I left it in for 3000 miles ,then removed for inspection.I found this filter collapsing in the middle.I called amsoil.They told me it was probally becuase the filter is so effective.I asked ,Doesn't this effect flow of oil?The response I got was,If your oil pressure gauge is reading normal,there isn't a problem .I sent the filter back to them for inspection.I WILL NEVER USE THIS FILTER AGAIN!I think it empedes the flow of oil.What do you have to say to that,BUSE?aka al's parrot [img]/ubbthreads/images/graemlins/bleh.gif[/img]
A $12,000 high performance diesel engine - and you are BARGAIN hunting for an oil filter? [img]/ubbthreads/images/graemlins/crazy.gif[/img]
First let me say I respect you opinion on technical advise that I have read being the lurker I am on this site but I must say as for you opinion on how others shop Not all of us are techs or employees and can get them at cost (20.00 from ford) most are quoted the usual 34.50 retail from the stealership parts counter. I myself can purchase at employee price but I will say I have purchased from checker before because of convenience. If you are doing your maint like ford recommend then that 12,000 retail (6,000 + or - 1,000 employee) high performance diesel engine should be ok with the other filters. So it is not crazy it is being consumer smart.
All the guy asked was are they the same and how they compare to the wix not what is the better bargain
2005 f250 fx4 charcoal grey sport 2.5"leveling kt 35x18 nito graplers on 18" mb preditors, xm satilite, CDT components in the doors, 2 planet audio 10" behind the seat and 2 planet audio amps
you said u used it only 3k and it collapsed? did u use amoil oil? did you happen to take a pic of the filter, was it a EaA88 filter? how long ago did that happen to you?
IDIABUSE you sound like the sales rep that is justifying his product. 4613 is only giving his opinion and the reason why it is his opinion
[/ QUOTE ]Are you for real???.I didn't use the correct filter [img]/ubbthreads/images/graemlins/rolleyes.gif[/img].As I said in my previous post,I spoke with amsoil about it.If you have anymore questions,contact them.Also,when you use amsoil filters,you have to use amsoil oil??GET REAL DUDE?How many brownnie points do you get from "Al" for these posts?PARROT .POLY WANT A CRACKER??[img]/ubbthreads/images/graemlins/eek.gif[/img]
[quoteyou said u used it only 3k and it collapsed? did u use amoil oil? did you happen to take a pic of the filter, was it a EaA88 filter? how long ago did that happen to you?
Ok, I will correct him. It should be a EAO88, not a EAA88. They did redesign the filters for the 6.0. It first started out as the same filter everyone else bought. It was not a synthetic media filter then. When AMSOIL switched to the synthetic media, AMSOIL designed there own filter. They actually most recently changed the design again to allow better flow for people using a By-pass system, and retaining the stock oil filter and plumbing through the filter cap and oil fill cap.
"The one I'm using also claims 98%."
When you claim that the one you are using also claims 98%, at what micron is it filtering 98% of? Is it 15 micron, or 25 micron. With the AMSOIL filter, the are the only company that I know of the claims 98.7% at 15 microns.
I am not tring to Hijac this post, just trying to clear some stuff up!
2006 F350 6.0 Auto CC 4X4 DRW LB
White Lariat 4.10 LTD Slip
Line-X, Transfer flow 57 gallon
Firestone Airbags, Colibert Hitch,
Recon lights, Truxedo Cover Edge A2
2004 F350 6.0 auto cc 4x4 drw lb
oxford white
xlt sport pkg.
4.10 ltd slp
aux idl ctrl
hd suspension
tt mirrors power
moon roof
Transfer flow 57 gallon replacement tank
Cap
Line-x spray in
Firestone Airbags
Edge w/juice
Amsoil 15W40
Purolator only specifies the 98%, not at what micron level. Not really wanting to debate who has better filters, as my point was that we need to be open to a few good filters in addition to the OEM and that Amsoil isn't automatically the hands down winner. I run their gear lube in my truck, but will not entertain drain intervals beyond 5k and thus their oil is not a cost effective solution for my needs. I do believe that at 5k intervals I'm getting very good protection and performance using Delo400. But, I'll see what becomes available when the new CJ-4 oils hit the streets
Mark
Built: 11/03/03
