Oil Filters - Page 3 - Diesel Forum - TheDieselStop.com
Old 08-21-2006, 02:29 PM   #31 (permalink)
Re: Oil Filters
You have convinced me ,and I am sure a few others here, to never use any Amsoil products. It seems that there online sales staff lacks facts to present and trys to annoy perspective customers with sounds of a broken record sales speech. Perhaps you should head over to the Chevy web sites.
'06 F-350 Lariet,CC,SB,6.0L,AT Bone Stock
colonelaberilla is offline
Old 08-21-2006, 03:36 PM   #32 (permalink)
Re: Oil Filters
sorry you find how I say things insulting, that wasn't what I intended. I take my truck and the job I ask it to do very seriously, like many do here. I know that Amsoil products are the best on the market and benifit anyone that uses them. I have tremendous respect for AMSOIL the company they built for the true auto enthusiast looking for better oppertunity, not just huge profits
1988 F250 dually 7.3 IDI Banks Sidewinder C-6 with GearVendors overdrive 3.55 ring gear
Amsoil 5w30HDD with full flow / bypass filters,
Evans coolant and Amsoil conical air filter.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline
Old 08-21-2006, 07:18 PM   #33 (permalink)
Re: Oil Filters
No one ever said you were insulting. Dont give yourself that much credit. We just think you're irritating.
New: 2008 F250 Lariat, CC, LWB, 4X4.
Old: 2006 F250 XLT, Ext. Cab, LWB, FX4.
sullyx7 is offline
Old 08-21-2006, 07:34 PM   #34 (permalink)
Re: Oil Filters
Oh, Crap! I just changed my oil (25K) and used Rotella and a Motorcraft filter. Is my 6.0 Doomed?
traildog
Rear main engine seal replaced @ 13,500 miles. Engine pulled for Bed Plate Leak @ 28,500 miles, hasn't leaked a day since (57K now)
2005 F350, 4X4, FX4, DRW, CC, Lariat PKG, Tow Boss, bone stock.
60K oil cooler, egr cooler, degas bottle, hoses.
traildog is offline
Old 08-21-2006, 07:51 PM   #35 (permalink)
Banned
Re: Oil Filters
[/ QUOTE ]BEST ON THE MARKET?Why doesn't Al put his oil up against REDLINE head to head?Because if you or Al know anything about synthetic oil,you know redline is a far superior oil.I am not a salesperson.Put up or shut up! [img]/ubbthreads/images/graemlins/eek.gif[/img]
sicaj is offline
Old 08-21-2006, 08:10 PM   #36 (permalink)
Re: Oil Filters
4613, Im sure Redline is good oil, I have used it in the past, it was better than what I used previously, but it was expensive and didn't last as long as what I found next. yes Redline is good, but they dont carry filters or advertise extended drain intervals past the OEM extended drain interval.
Amsoil started in 1972 with 25k oil drain
Redline started selling oil in 1979 oem drain intervals
Redline is one of the best oils on the market to buy.
use what you want, benefit from it [img]/ubbthreads/images/graemlins/grin.gif[/img]
IDIABUSE is offline
Old 08-22-2006, 01:33 AM   #37 (permalink)
pajuis's Avatar
My Photos: (6)
Re: Oil Filters
Yesterday I saw the Puralator filters are now 2-piece. The filter has the felt washers on both ends and the part that clips to the filter cap is separate so the filter goes in either way then the top fits into the filter. Later I was O'Reilley's and they had the same filter in their brand for $9.99. I don't see any problem in using these filters. They sure looked better that the new WIX.
First of all, I want to tell you I am sorry your post went to hell. I have used the Purolator filters twice and I have not seen any problems with them. I change my oil more than needed or recommmended just because I like to. However, if you plan on extended intervals, I think you should probably go with a better quality oil filter.
Just my .02 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My Ride
2005 F250 XLT CrewCab FX4 Silver Metallic
Reverse Aid Sensors, 10.5" DVD Monitor
6" Fabtech Lift, 1.5" spacer 37" NITTOS on Pro-Comp Wheels,
Airaid Intake, Hypertech 41045 3 Stage in-line PTC,
4" turbo back Diamond Eye exhaust with cat delete,
Crimestopper alarm, perimeter sensor,
remote starter ,turbo timer,
tinted windows ,billet antenna,
billet fuel door and Carbon Fiber taillights.
pajuis is offline
Old 08-25-2006, 12:08 AM   #38 (permalink)
Re: Oil Filters
Just an FYI - ask Amzoil who makes their filters? They are an oil producing company and have now gotten into the filter business on a limited basis. Could it be who quotes them the cheapest price? Maybe Fram/WIX/or Purolater? Next time any of you call them, just ask and see what kind of an anwer you get.
Nelly3 is offline
Old 08-25-2006, 12:59 AM   #39 (permalink)
beachbumcook's Avatar
Re: Oil Filters
I called Racor and got the answer from a guy named Dave in technical support.
Racor makes the OEM oil and fuel filters for Ford (someone else makes the tranny filter).
The Racor's filters or Motorcraft as they make those too.... filter to a lower micon level than other "will fit" filters. I had called to find out the micron level and why my Blackstone reports are coming back as good as those running by-pass filters in addition to the stock set-up.
"Will fit" filters filter to 40 - 60 micron, yet the Racor/Motorcraft made filter goes dowen to 20 micron right out of the box. Have no idea if the new Amsoil 6.0L oil filter is good or not, but if it started to collapse.. then there is a filtering or pressure problem... good or bad... it's a problem.
Amsoil claims to filter better and trap more... but if it is, then how does one know when to change it? Since they cost more Amsoil justifies the cost by longer change intervals.... but with a collapsed filter... you and your truck suffer!!!!
By Motorcraft filters at Walmart or your local Auto Parts Store for $19.99/ea and rest easy!!!!
It has become widely known on this site that oil and filter changes every 5,000 miles is key regardless of how one drives. This motor likes clean/fresh oil and since the motor shears it doen, frequent changes is key!!!!
03 Excursion 6.0L PSD - 4X4 Limited
Pioneer Airware XM2GO Statelite Radio
Racor By-Pass Oil Filter
Magnefine P/S Fluid Filter
Dieselsite Coolant Filter
Fumoto Oil Drain Valve/Plug
Marinco AC Block Heater Plug Mod.
Bilstein Shocks
Rancho Steering Stabilizer
Brite Box Headlight Module
24" Wiper Blades
beachbumcook is offline
