Oil leak around oil cooler - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 06-03-2012, 06:48 AM Thread Starter
I am new to diesels and to the forum. I have a 04 f250 6.0 148,XXX. I was looking under my truck tonight and noticed oil on most surfaces under the engine and aft of the engine. Climbed on top of the engine and noticed significant oil on top of where my egr oil cooler line "blue line" connects to the top of my oil cooler. Nothing forward of that just aft of it and down both sides of my engine. Does anyone have any ideas of what this could be. I just ordered an egr delete and a blue spring upgrade. While I have the turbo off what should I look for or replace, or is there anything I can do in the mean time until I get the parts and start tearing into it? Thanks for any input!
Sent from my PC36100 using AutoGuide.Com Free App
avmt_88 is offline
post #2 of 8 (permalink) Old 06-03-2012, 09:56 AM
The oil filter housing has an o ring that can leak that high. The oil pressure switch and oil temp sensor could too.
Clean up that area with engine degreaser and hose it off and then go for a drive and see if you can see a fresh trail of oil starting to pinpoint where the leak is from.
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 136K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
2002 F350 CC DRW flatbed (originally pickup bedded) rebuilt & upgraded 4R100
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 164K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 241K (no engine repairs)
2007 BMW 550i 6MT 146K, Stuff breaking all the time that would last twice as long on a Kia or Hyundai, sad. Drives great though.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #3 of 8 (permalink) Old 06-03-2012, 05:55 PM Thread Starter
Thanks a lot I will try that tonight!
avmt_88 is offline
post #4 of 8 (permalink) Old 06-07-2012, 07:55 PM
leak
I have a cooler leak on a 08 it was the gasket betwene theblock and the cover
fleet diesel tech.
thw1 is offline
post #5 of 8 (permalink) Old 06-08-2012, 12:29 AM Thread Starter
My problem is i cannot find it. i degreased everything and today i was helping someone move so i was pulling a trailor and i parked for maybe an hour in the one spot and when i left she called me and said that i had left a baseball sized spot and 2 other golf ball sized spots in the driveway... when i got home i looked under the truck and it seems to be coming down both sides of the engine??? one spot it was dripping onto was the driveshaft and the on the other side it was coming down off the right side of the oil pan. i just bought this truck recently and am having horrible luck with it as far as the oil leak goes. the parts for my egr delete and blue spring kit just came in the mail. what should i replace or look at that could be a potential problem while the turbo and egr cooler is off?
avmt_88 is offline
post #6 of 8 (permalink) Old 06-08-2012, 06:59 AM
Iam re sealing the whole oil cooler housing there are several o rings and gaskets the leak was comming from the front side betwene the block and the cover ran down both sides of the block .
fleet diesel tech.
thw1 is offline
post #7 of 8 (permalink) Old 06-09-2012, 01:30 AM Thread Starter
Once i pull my turbo and everything off hopefully i will be able to see where the leak is coming from... do you happen to know a part # for the oil cooler o-ring kit if it does happen to be the same thing on mine?
avmt_88 is offline
post #8 of 8 (permalink) Old 06-09-2012, 12:25 PM
Sorry i dont think it was a kit they were all seperate
fleet diesel tech.
thw1 is offline
