Oil Leak Blown Head Gasket???????? - Diesel Forum - TheDieselStop.com
Old 08-23-2006, 08:28 PM   #1 (permalink)
Well it finally happened....my beloved 03 is in the dealership having the head gasket replaced. I arrived in reno to find oil dripping from the back of the engine. It didnt loose enough oil go below the dipstick mark but lowered a little. However i didnt notice any performance losses on the way home, ran great. However the dealership sais that the head gasket is leaking and that they are going to replace both. 74K on the milage so its covered. Is this a common problem??? Or has anyone else had experience with this??
02/03 Build date
74K milage-first problem
Current on all flashes (Shots..hehe)
-rob
Stock, New HPOP
Lots of car seats
JonGage is offline
Old 08-23-2006, 09:30 PM   #2 (permalink)
KingKong's Avatar
My Photos: (11)
Re: Oil Leak Blown Head Gasket????????
They have replace mine twice and it still leaks oil on the right side around the heads.
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
KingKong is offline
Old 08-23-2006, 09:32 PM   #3 (permalink)
KingKong's Avatar
My Photos: (11)
Sorry just a little bit of info don't let them resurface the heads if they or warped they need to be changed not resurfaced my truck only has 14000 miles on it
KingKong is offline
Old 08-25-2006, 11:05 PM   #4 (permalink)
Send a message via AIM to PaCeMaKeR
if you have a rear mounted icp sensor on your 03 im almost positive that where your oil leak is, i havent seen too many of the headgaskets leaking oil, but what the hell, get em changed. are you going to upgrade to the arp headstuds?
2002 PSD modded " tow rig"
92 Dodge Cummins
86 Buick Grand National
PaCeMaKeR is offline
Old 08-26-2006, 09:06 AM   #5 (permalink)
I'm surprised your not blowing coolant. Often, when the head gasket is breached, the coolant system gets pressurized when you get on her, and it spews out the reservoir. Any white spots around the coolant reservoir? Ever smell antifreeze?
If not, I bet your head gaskets are fine and it is the ICP leak that PaCemkr mentioned. If you have any plans for extra power, do the ARP or other suds instead of stock bolts. Small price to pay up front, trust me!
Ralph
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 08-26-2006, 11:06 AM   #6 (permalink)
bigwhite1's Avatar
mine is blowing antifreeze, just started while pulling the trailer up a hill. i would have expected power loss if the head ggasket was leaking, but i didn't get any so i suspected the EGR cooler was causing it. i unplugged the EGR and it stopped blowing antifreeze, also i got another 60 miles to the tank in mileage. so i'm hoping it's only the EGR, what do you guys think?
unfortunate owner of a 2006 6l diesel,lb,cc and formally a 2004 6l. both puke and both not fixed by ford under warranty
2004 cardinal 33ts
bigwhite1 is offline
