Oil leak on new F250 Powerstroke ( 2005) - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 07-27-2005, 01:26 AM Thread Starter
Hey guys,
I need some input on this. I noticed yesterday that I had a small amount of oil on the garage floor. I got up under the truck with my flashlight and noted quite a bit of oil on the underside of the engine. I think I located the point of origin which is just behind the harmonic balancer ( I think that is what it's called). There is a recessed looking plug, I am guessing about a 3/4 inch allen driver would fit it. The oil looks to be coming from there. I have read some earlier posts about rear main seals, and I have also hear mention of a front main seal. Where is this located, or is the place I am trying to describe the location of the front main seal. I have about 8000 miles on the truck. I purchased it about a month ago and have taken a very long trip. I have not towed anything, just driving down the highway. Any input on this would be greatly appreciated.
Regards,
John Curry
2005, F250 4X4, Lariat,(FX4) Crew Cab, Captains Chairs, PSD 6.0,Torque shift 5 speed automatic, Tow command, upfitter switches,power sliding rear window,6CD, Wedgewood Blue w/Beige accent, Build date 1/05/05 "Bone Stock and staying that way"
Remember, amateurs built the Arc, professionals built the Titanic.
jcurry is offline
post #2 of 9 (permalink) Old 07-27-2005, 01:36 AM
hitecdan's Avatar
My Photos: (23)
Re: Oil leak on new F250 Powerstroke ( 2005)
I think your looking at the crankshaft position sensor (CKP) . It's not uncommon for it to leak from the factory. You'll have to take it back to the dealer to have them fix it. From what I hear, it's real fun to replace the o-ring on the CKP.
My html Version of the
Now with 2005 Updates
Born on date: Jan 20, 2003
Number of C94 injectors replaced: 1 (#4 Jan 30, 2015)
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 9/17/2014)
hitecdan is offline
post #3 of 9 (permalink) Old 07-27-2005, 03:02 PM
My Photos: (5)
If the engine was made at the Indy plant between about Thanksgiving '04 and the beginning of February '05, it's probably (okay, most likely) a front main seal. The plug with the 12mm hex socket is for the lube oil pump PRV. Since it's the low point, stuff from the front main wanders down there and drips off it. Your dealer may just reseal the PRV cap (because it's a 10-minute fix), but you'll be paying him another visit 'cause it probably won't stop the problem.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Now I do subsea ROV tooling.
AutoJim is offline
post #4 of 9 (permalink) Old 07-27-2005, 03:11 PM
Front main seal....
2005 f250 PSD 4x4,CC,LB Magnaflow 4" turbo back exhaust.
moovet is offline
post #5 of 9 (permalink) Old 07-27-2005, 03:51 PM
Front Main Seal. Had mine replaced two weeks ago.
2005 F250 CC PSD Lariat 4x4
kbobk is offline
post #6 of 9 (permalink) Old 07-29-2005, 11:36 PM
Front main seal....
ditto
2005 F-250 CC SWB XLT-Sport 4x4 All White
Engine Built 01/04/05 in Indy
2005 Cadillac CTS-V
"He's dead now!" United States Marine Falluja, Iraq
American_Pride is offline
post #7 of 9 (permalink) Old 07-30-2005, 06:39 AM
Me, too. Front main seal, for sure. My dealer found the o-ring for that plug leaking as well, but they fixed it all the first time- it took one day to get the parts, and one day to fix it. Don't le them jack you around or you will be taking it back several times. It's the front main, and they know it. They'll try to placate you with half-ass quick-fixes if you let them.
Red 2002 F-350 XLT SRW 4x4 7.3L reg. cab 6-speed rubber floors traded at 50K for:
Red 2005 F-350 XLT SRW 4x4 6.0L reg. cab 6-speed rubber floors BFG 12.5x35 mud-terrains, no lift traded for:
Red 2008 F-350 XLT SRW 4x4 6.4 reg. cab 6-speed. Got carpet this time- audiophile stereo deletes rubber floors. BFG 12.5x35 mud terrains, no lift.
Traded at 45K for: Red 2011 F-350 XLT SRW 4x4 6.7L reg cab BFG 12.5x35 mud terrains, no lift. "optioned" out of- stick shift, rubber floors, audiophile stereo, fog lights, chrome step bars GRRRRR!
torino73 is offline
post #8 of 9 (permalink) Old 08-02-2005, 07:07 PM
Welcome aboard!
2004 Dodge Ram 2500
Cummins 5.9L Turbo Diesel producing:
600 ft lb torque @ 1600 rpm
325 hp @ 2900 rpm
19000 lb towing capacity
billyrae is offline
post #9 of 9 (permalink) Old 08-02-2005, 08:27 PM
compman72's Avatar
My Photos: (9)
How long was your truck in the sick bay to have the seal replaced? 1 day or more?
I have the dye in the oil now and have to take it on next Monday next week to hopefully have the leak fixed. I have been patient with the dealer so far. I have already had the PVR replaced.
2008
F250 XL Crew cab, manual 4x4, 6.4L, Job 3, TorqueShift, w/ Decor group, Camper Pkg, Off Road Pkg, LWB, Power Equipment Group, Tow Command, Knapheide Utility Bed with sliding top. Built 2/5/2008 & Purchased 9-1-08
08B07 Flash 1-16-09
Firestone Ride Rite Air Springs 3-20-09
Radiator (end cap leak) @ 34,100 miles 11-19-09
11B23 PCM Recalibration 4-11-11
Hydroboost Replacement (leaking Power Steering Fluid) @ 82,866 miles 7/25/11
Upper & Lower Hoses (new design) @ 90,000 miles 11/10/11
Break Pressure switch (cruise control failure) 99,300 miles 3-13-12
New BF Goodrich Rugged Trail T/A tires after 101,400 miles on the original
BF Goodrich Rugged Trail T/A tires 3-27-12
New Batteries after an original boiled over at 105,300 miles 5-13-12
Fuel Pump Replaced (frame rail) 131,534 miles 4-5-13
compman72 is offline
