Oil Pan Drain Plug Size - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-21-2008, 06:17 PM Thread Starter
Chief-Gator's Avatar
I just bought an 04 F250 6.0L and want to change the oil and the drain plug, but I can't seem to find the size/spec for the plug and don't want to take it out before I have another to replace it. The existing one is leaking slightly and it needs to be replaced. Can someone tell me the size/spec for this plug?
It looks like there may be another small oil leak somewhere, but that seems to be a common thread and I'll post more on that later once I get into it. Trying to solve the obvious issue first.
Chief-Gator is offline
post #2 of 8 (permalink) Old 04-21-2008, 11:23 PM
dieselmankane's Avatar
19mm (metric), i think.
2003 F250 Super duty 6.0 PSD, was great in the beginning, but started to have major issues:
Traded, Oct 2 2008 for...
New truck: 2008 F250 Superduty Lariat 6.4 PSD Job 3, black, with ALL the goodies, very impressed so far...
[SIGPIC][/SIGPIC]
dieselmankane is offline
post #3 of 8 (permalink) Old 04-22-2008, 12:01 AM
Actually maybe it takes a 3/4" wrench.
[SIGPIC][/SIGPIC]
post #4 of 8 (permalink) Old 04-22-2008, 12:14 AM
I just changed mine today in the driveway I used a 3/4" box end wrench it was a tad sloppy so I think it is metric but the sae worked on it just fine.
2004 F350 xl super duty C/C long box 4x4 auto 6.0 ltr. airraid filter 4" magnaflow turbo back system, zoodad 209000 kms.
Past truck 1992 F250 XLT 7.3 IDI ex-cab 4x4 auto 372,000 kms. It ran great; then a moose killed it!
pgjeepster is offline
post #5 of 8 (permalink) Old 04-22-2008, 12:29 AM
There you go, i have changed mine with the 19mm, but sounds like the 3/4 will work to.
[SIGPIC][/SIGPIC]
post #6 of 8 (permalink) Old 04-22-2008, 02:37 AM
Banned
19mm converts to 0.748 inch... 3/4 is 0.750 inch... 0.002 inch is kind of a moot point when it comes to wrench size.
However, the OP is looking at buying a new drain plug and, I think, is more interested in shank diameter and thread pitch...
If the hex on the plug isn't mangled.... if the threads are in ggod shape..... and if the copper washer isn't near destroyed, try flipping the copper gasket downside up....
Now... here's a real "off the wall" suggestion... One visit to the "stealership"... Yep, there might be a little "pucker factor" when the price comes up... But one simple little visit to the "stealership" and you should walk away with the object of your desires.... No wishing, no hoping, no disappointments when you go to put things together again.
I can't speak for anyone else... but I see guys spending hours and hours to "save" a buck... Every hour I spend trying to save a few bucks takes me away from doing those things that earn me many bucks... It's called "false economy". We think we are doing good because it lowers our maintenance costs.... How many "billable" hours does it consume?
GrampyJim is offline
post #7 of 8 (permalink) Old 04-22-2008, 09:11 AM
JIM_C's Avatar
My Photos: (5)
Or you could replace the drain plug with a Fumoto valve. Pretty sure the correct size is F111 but double check. fumoto oil drain valves
2014 F250 Platinum CC Short Bed 4x4, 6.2 (I Got Gas Now!)
2003 F250 XLT CC Long Bed 4x4, 6.0 w/Auto (SOLD)
JIM_C is offline
post #8 of 8 (permalink) Old 02-13-2011, 01:12 PM
dennisj2003's Avatar
Or the OP could be like me searching for a diff ave, I am needing a tee to fit the oil pan with one male and two female conn, so I can install my bypass filter an use the fumoto valve also.
dennisj2003 is offline
