Oil pressure gage drop at idle! - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 10-06-2011, 04:52 PM Thread Starter
My original problem was the check engine light coming on at idle and the oil pressure gage dropping to zero, but when I hit the gas everything would be normal. It runs great, but has a hard time starting. From the forums I figured it was the HPOP. I tore everything down and noticed a potential gasket leak so, but everything else looked great with the HPOP. I put everything back together, got her started and went on down the road. Same problem came back. My batteries are very old and don't hold a charge long at all. Can this check engine light on low oil pressure and hard starting be a battery issue? I also discovered I have an early 04 6.0l powerstroke which doesn't have the STC fitting on the HPOP.
David
dmageetx is offline
post #2 of 14 (permalink) Old 10-06-2011, 04:59 PM
I'm sure others will chime in with more experience. But, my understanding is that the oil pressure indicator on the dash is hooked to a switch that closes at 8 psi. So, if it is working right your pressure could be going below 8. I think this would be the low pressure oil pump. However, it could just be the sensor. I don't know if the truck would run if your oil pressure actually dropped that low.
My understanding is also that bad batteries can can all sorts of electrical problems on these trucks, including ruining the FICM. Good idea to put good ones in.
June 2004 F350 6.0L, 4 Door Supercab XLT SRwd Short Bed, Automatic, Deluxe Aluminum wheels, Class V Trailer hitch receiver, 3.73 standard rear end. Line-X bed liner, 5th wheel hitch, Brakesmart trailer brake control and Powerlock starter interlock. Coolant filter. Fully Bullet Proofed.
Larryect is offline
post #3 of 14 (permalink) Old 10-06-2011, 07:34 PM
Feedback Score: 2 reviews
First thing you need to do is get a new set of 850CCA batteries in because the old one will KILL the FICM $300 to repair or $1100 from Ford then go from there to the next problem.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #4 of 14 (permalink) Old 10-07-2011, 10:30 PM
You most likely need a high pressure pump. There is a ball bearing that falls out on the low pressure side of pump. When this ball bearing falls out, the oil bleeds back into crankcase instead of feeding high pressure pump.
djshum is offline
post #5 of 14 (permalink) Old 10-07-2011, 11:15 PM
I don't believe the truck would be running w/ that HPOP ball bearing missing.
Mark
bismic is offline
post #6 of 14 (permalink) Old 10-08-2011, 12:33 AM
05_HARLEY_F250's Avatar
Check that sensor, nasty oil or other garbage can plug it up keeping the oil and the pressure from it causing it to read improperly and as you already know the engine shut down is a protective feature.
Replaced or Updated: Radiator, thermostat, heater valve, degas cap, Stock Head gaskets, oil cooler, Harley Davidson windshield. ARP studs, STC, stand pipes, dummy plugs, Motorcraft max batteries, turbo oil supply & drain, Blue spring, Fuel/water separator drain plug, interior light LED conversion, Recon smoke LED tail lights, third brake light & mirror lights & added Big rig ice running board and Fire & ice tailgate strip. Other mods: Garrett powermax turbo with riff raff SP billet wheel & boots, Metal CAC tube w/cool it thermo tec aluminized coating, Harpoon, tailgate assist, Drilled/slotted rotors w/ceramic pads, Goodyear Wrangler Duratrac 275/65R20 & Gatorback belt, IPR Generation 2 EGR & up pipe delete. MBRP 5" turbo back SS straight, IPR coolant filter, Rotella ELC conversion Fumoto; oil drain, block drain x's 2, CCV drain. Electronics: PHP Gryphon/Eco, Atlas 40,80,Herc, Edge CTS insight w/EGT, Upfitter switch, high idle mod, JVC KW-NT700, Viper 5904 2-way.
05_HARLEY_F250 is offline
post #7 of 14 (permalink) Old 10-08-2011, 06:22 PM
It can, and will run with that ball missing...and the oil pressure gauge will show no oil pressure at idle. Have seen it 2 times. That ball is on the low oil pressure side, there is enough volume to feed the high pressure pump to allow engine to run but not enough make gauge register.
djshum is offline
post #8 of 14 (permalink) Old 10-08-2011, 11:36 PM
Interesting - I had not seen that before.
Mark
bismic is offline
post #9 of 14 (permalink) Old 10-26-2011, 04:37 PM
Just going through the same exact thing. I spent $5700 last year for new headgaskets, ARP studs, Bulletproof cooler, radiator etc. Now the engine was hard starting and my oil guage would fall to zero at stop lights. Getting a new HPOP, new FICM, new oil cooler and all for only $3900 for a truck that is worth $12000 (2004 Lariat). I hope it runs for another 150000 miles cause I am going to keep it.
-2004 F-250 super duty diesel Lariat
-Torreador red with beige trim
-Fx4
-Ramsey winch
-H&K usp compact/.40 S&W
gleninaz is offline
post #10 of 14 (permalink) Old 10-26-2011, 05:21 PM
The oil pressure guage reads the low side of the system. I also thought the ball bearing was in the HPOP housing as a plug and would not let the vehicle run if missing. I guess we all learn something. You should get batteries for sure.
lenzhotrod is offline
post #11 of 14 (permalink) Old 10-26-2011, 09:22 PM
I see this pretty often. Replace the sender, they often fail or leak. I install a new one with every oil cooler.
Kevooo is offline
post #12 of 14 (permalink) Old 05-09-2015, 11:13 AM
I have an early 2004 superduty 6.0 also. Was having a hard start issue oil gauge would drop to 0 at idle give it the gas and everything works fine. Told by the shop my HPOP was bad so I changed my HPOP, oil tube, IPR sensor, and oil pressure sensor. Now it will crank up no problem oil pressure gauge works until oil gets warm then it drops to 0 at idle and the skipping is getting worse.
UpsetFordOwner is offline
post #13 of 14 (permalink) Old 05-09-2015, 02:07 PM
Since you have changed almost the whole HP oil system of course it will work. LOL How much actually had to be changed is maybe a different story.
Just saying not fussin or nitpicking.
dannyboy950 is offline
post #14 of 14 (permalink) Old 07-03-2016, 06:19 PM
I have an 06 6.0 f250 that just recently started the same thing. No problems at all except the gauge dropping to 0 and the "check gauges" tone chiming. I am concerned that it may cause me to get stranded although I feel and see no change to the trucks operation whatsoever when it does it. I'm leaning and hoping that its just the sensor. So I may buy that sensor and start there. Hoping that fixes it. At 248k miles i have had a rash of things that are starting to crop up just mainly due to lack of proper maintenance from the prior owner. Ball joints u joints and the like.
Foslful is offline
