Oil Pressure Gauge drops to zero at Idle - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 11-21-2007, 07:47 PM Thread Starter
A friend has a 2004 6.0 with a strange problem, anyone heard of this before? Truck runs fine, but all of a sudden sitting at a stoplight the oil pressure gauge will drop to zero and the CEL comes on, then the engine quits. Restarts right away as if nothing happened. I know the engine needs oil to run the injectors, but do you think it is actually a bottom end engine problem or a sender/computer issue? Buddy has been drivin like this for a couple weeks, he just pops it into neutral at stoplights now.
2007 F350 4X4 King Ranch SRW CC SWB 6.0, Black/Beige, Factory 20s, Shaker 1000 from 05 'Stang into a Rockford Fosgate 360.1 processor, Phoenix Gold MS275, MB Quart 5x7s in stock location, JL 13TW5 shallow mount sub, Reese 5th wheel hitch, gonna be lifted one day, Now rollin on 33x12.5x20 Dick Cepeck F-C IIs with no lift...
2002 F-350 XLT DRW CC SWB 7.3 auto 4X4, 4.5" Revtek lift, 255/85R16 BFG Muds, 4" Magnaflow turbo back, Tekonsha Prodigy brake control, XM Skyfi, Deflecta-shield SealTite x-over toolbox, line-x, Ford AIS. For sale soon!
2007 Thor Tahoe Transport 244FS Toy Hauler
2005 Honda Rincon 650... GPS, 27" Mud-lite XTRs on 14" SS112 rims, custom 3.5" exhaust tip made from and old 6.0L PSD downpipe hahaha, Highlifter front Disc brake conversion, K&N, more to come...
alberta60 is offline
post #2 of 5 (permalink) Old 11-21-2007, 07:56 PM
weasel79's Avatar
Re: Oil Pressure Gauge drops to zero at Idle
Possibly a low pressure oil pump problem. I would tee a pressure guage in with the oil pressure switch just to be sure. If it is weak it might not be able to supply the hpop with oil. Or possibly the relief for the low pressure pump might have a problem.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe,
weasel79 is offline
post #3 of 5 (permalink) Old 11-22-2007, 11:00 AM
Get that truck in to Grampy Jim. PM him for his location. He's a 6.0 whiz!
2005 Eddie Bauer X -- all stock.
Wren is offline
post #4 of 5 (permalink) Old 11-22-2007, 11:37 AM Thread Starter
We'd love to, but Grampy is about an 8 hour drive north of here! The local dealer had a look at this truck about three months ago because it was losing coolant like crazy and blowing white smoke (steam) at startup. They told him it was head gaskets and quoted $5000 for the job. He didn't have that kinda cash at the time, so the truck sat for a while, and then I read here on the good 'ol DieselStop about EGR cooler failure and that seemed to match his symptoms better that Head gaskets, so we popped out the EGR valve and sure enough, it was all wet! So we grabbed a used egr cooler off of my old overheated 6.0 from a couple years ago, and spent a saturday (and a couple dozen cool ones)changing it out. Problem solved, no coolant loss now! Thanks to TDS!
Truck ran fine for about a month, now this oil pressure problem. I think we'll check oil pressure with a gauge first, maybe swap sending units as we have a complete overheated 6.0 sittin here collecting dust.
He's running a Superchips 1704 Tuner and a cat back dual exhaust, 4" lift w/35s, stock otherwise.
post #5 of 5 (permalink) Old 11-22-2007, 02:59 PM
ritschner's Avatar
Send a message via AIM to ritschner
More than likely it is the sending unit or the connection itself. The sending unit is an on-off switch that sends the gauge(idiot light with a needle) to the middle. A break in the circuit will send the gauge to zero and shut down the truck. Try just unplugging the sending unit and checking the connection for corrosion..
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
