oil pump grenaded - Diesel Forum - TheDieselStop.com
Old 10-15-2009, 02:05 PM   #1 (permalink)
oil pump grenaded
Has anyone heard of the oil pump exploding, mine just did.
Inner gear was in 6 peices, outer gear cracked which cracked the oil pump/water pump housing.
Cost to get fixed 2285.
Runs like a champ
truck has 65,500 miles, never had any issues except normal EGR valves, two replaced under warranty.
I would insert picture but cant figure out how.
Fallonpowerstroke is offline
Old 10-16-2009, 06:55 AM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
You must have been redlining it pretty high. Most LPOP failures are caused by high RPMs and heavy engine stress.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 10-16-2009, 09:58 AM   #3 (permalink)
Texascadillac42's Avatar
My Photos: (10)
^^^^ that was my first thought as well....but I wonder if something got in there and "jammed" the oil pump gear causing everything to shatter.
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 10-16-2009, 10:26 AM   #4 (permalink)
I was driving to work about half way i did a full throttle pull in first gear, with my Bully Dog Power Pup at 100%. I dont think i redlined but i may have. Under acceleration i heard a squeel and the engine just shut down.
I have been going pretty easy on it since i got it back, so far so good. Havent reinstalled the programming yet, will wait a week or two.
You can check out my photo's for the carnage
Old 10-16-2009, 10:32 AM   #5 (permalink)
My Photos: (10)
What year was the truck? I have heard of a handful of oil pump failures on 03, early 04 trucks with the "smaller" water pump/front cover.
There was some discussion on competitiondiesel.com about the use of Fluidampers causing oil pump failures, but in the end the general conclusion was that most people running Fluidampers were really pushing their trucks harder, which led to premature oil pump failures. Most of these failures were in earlier (03 to early 04) trucks.
Old 10-16-2009, 01:27 PM   #6 (permalink)
My truck is a 04, build date was Jan 04. I ordered the truck took delivery in Mar 04.
CrewCab 4x4
6-speed
Old 10-16-2009, 01:32 PM   #7 (permalink)
complete description below
04 F250 Crew Cab 4x4 6-speed, Bully Dog Power Pup w/Outlook Monitor, AFE Proguard 7, MBRP Turbo back with cat delete, 5.5 Tuff Country Lift w/ladder bars, 35x12.50x17
Old 10-16-2009, 08:38 PM   #8 (permalink)
OT
OT's Avatar
Sounds like u were trying to smoke someone else, but smoked yourself instead? At least your h.g. didnt blow. Sure wierd. Anyhow..better luck next time..pedal/metal.
btw..see u figured out how to on pic's.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 10-16-2009, 10:14 PM   #9 (permalink)
Not racing anyone just every now and then like to play around. The truck amazes me all the time. Its a blast to drive.
